| Thread Closed |
Ratio of Flow Rates. |
Share Thread | Thread Tools |
| Jan15-10, 06:08 PM | #1 |
Two tubes carry the same incompressible fluid with viscosity 1.5 Pl. They have lengths L1 = 6 and L2 = 22 m and diameters d1 = 1.2 and d2 = 4.5 cm. What is the ratio of their flow rates F1/F2? 2. Relevant equations Poiseuille's law: 8nLI/(pi*r^4) while n is viscosity L is the length R is radius 3. The attempt at a solution F1= (8*1.5*6*I) / (pi*(1.2/2)^4) F2= (8*1.5*22*I) / (pi*(4.5/2)^4) The ratio F1/F2 is: (8*1.5*6*I) / (pi*(1.2/2)^4)* (pi*(4.5/2)^4)/ (8*1.5*22*I) F1/F2= 46.296*1.1649= 53.932. And this is wrong, can u help?? |
| Jan15-10, 06:22 PM | #2 |
Recognitions:
You need to write out your steps more clearly. 8nLI/(pi*r^4) is not Poiseuille's equation; Poiseuille equation is ΔP=8nLI/(pi*r^4), where I represents flow rate. You now have 2 equations:
ΔP1=8nLI1/(pi*r1^4) ΔP2=8nLI2/(pi*r2^4) If you assume the two ΔP's are the same and divide one equation by the other, you'll see your mistake. |
| Jan15-10, 06:32 PM | #3 |
Thank you alot :)
| Thread Closed |
| Thread Tools | |
Similar Threads for: Ratio of Flow Rates.
| Continuity Equation - Why do the flow rates have to be equal? | General Physics | 4 | ||
| Question on flow rates over a weir. | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Water mixing temperature- different flow rates | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Flow Rates through multiple Valves | Mechanical Engineering | 3 | ||
| Pressure and flow rates | Introductory Physics Homework | 1 | ||
