Calculus Problems, triple integral and polar coordinates stuff
The discussion revolves around three calculus problems involving triple integrals and polar coordinates, specifically focusing on volume calculations related to geometric shapes such as spheres and cylinders.
  • Mixed
  • Participants explore various methods for calculating volumes, including using cylindrical coordinates and slicing regions into known volumes. There is uncertainty about the setup of integrals and the limits of integration, particularly regarding the cylindrical coordinates for the second problem.
Some participants have offered guidance on how to approach the problems, suggesting methods like slicing and using the Pythagorean theorem. There is ongoing exploration of the correct limits for integrals and how to account for the geometry of the shapes involved.
Participants are working under the constraints of a homework assignment with specific problems to solve, and there is a noted uncertainty about certain assumptions and definitions related to the geometric figures involved.
mmmboh
Hi I have a homework set due this week, 14 problems, I have done 11 of them, but these 3 are giving me trouble, help would be great :)
1.A cylindrical drill with radius 4 is used to bore a hole through the center of a sphere of radius 8. Find the volume of the ring shaped solid that remains.
2.Use cylindrical coordinates to evaluate the triple integral [tex]\int\int\int_{E}[/tex] [tex]\sqrt{x^2+y^2}[/tex]dV , where E is the solid bounded by the circular paraboloid z=9−(x^2+y^2) and the xy -plane.
3.A volcano fills the volume between the graphs z=0 and z=[tex]\frac{1}{(x^2+y^2)^2}[/tex], and outside the cylinder x^2+y^2=1. Find the volume of this volcano.
1. For the first one I know the volume of a sphere is 4/3[tex]\pi[/tex]r^3...so I found the volume and then I subtracted what I thought would be the volume of the cylinder, [tex]\pi[/tex]r^2h...for the height I used 16 because that's the diametre of the sphere sphere but I realized that the height of the cylinder will be a bit less but I can't figure out how much, and I would like to solve it with calculus too if I can but I can't figure out how to set up the integral.
2. For number two I have the integral as r^2dzdrd[tex]\theta[/tex], with the z limits 0 to 9-r^2, the r limits 0 to 3, and the [tex]\theta[/tex] limits 0 to [tex]\pi/2[/tex]...I am mainly uncertain about the [tex]\theta[/tex] limits, but am not sure about the others or the integral either. Is it right?
3. For the third I am not sure how to set up the integral, help please.
Thank you!
Hi mmmboh! :smile:
(have a theta: θ and a pi: π and an integral: ∫ and try using the X2 tag just above the Reply box :wink:)
With problems like this, always slice the region into slices whose volume you already know.
In this case, slice the hole (well, you know what i mean! :rolleyes:) into concentric cylindrical shells of thickness dx. :smile:
Yes, that's fine, except that θ always goes from 0 to 2π. :smile:
Same method as 1. :wink:
Draw a picture, looking at the picture from the side. You have a circle with a vertical rectangle taken out of the center. Draw a horizontal line from the center of the circle to one side of the rectangle and draw a line from the center of the circle to the point where that side of the rectangle crosses the circle. You now have a right triangle where the hypotenuse of the triangle has length the radius of the sphere, 8, and one leg has length the radius of the drill, 4. Use the Pythagorean theorem to find the length of the other side which is half the length of the rectangle. The only part of this problem that requires calculus is finding the volume of the "caps" on each end of the rectangle that are taken out by the drill.
Projected into the xy-plane, you get the circle [itex]z= 9- (x^2+ y^2)= 0[/itex] or [itex]x^2+ y^2= 9[/itex], with radius 3. Take [itex]\theta[/itex] from 0 to [itex]2\pi[/itex], r from 0 to 3, and z from 0 to [itex]9- (x^2+ y^2)[/itex].
Thank you!
Draw the graphs of [itex]y= 1/x^4[/itex], x= -1, and x= 1 (vertical lines), giving a cross section of the figure. Of course, because of the symmetry, [itex]\theta[/itex] goes from 0 to [itex]2\pi[/itex]. The vertical line x= 1 intersects [itex]y= 1/x^4[/itex] at x= 1, of course, so r goes from 1 to infinity. Finally, for each[itex]\theta[/itex], r, z goes from 0 to [itex]1/r^4[/itex]. Integrate [itex]dV= r dzdrd\theta[/itex] with those limits of integration.
Hm I'm not quite sure I completely understand how to draw the circle...
So far I have x^2+y^2=16 (equation for cylinder), and x^2+y^2+z^2=64 (sphere)
That means that z^2=64-16=48, and z=+/- [tex]\sqrt{48}[/tex], so the cylinder has a height 2[tex]\sqrt{48}[/tex]...from this I can find the volume of the cylinder, but how do I find the volume of the spherical caps?
Thanks for your guys' help! :)
Any help please?
You have to cut the region into slices
Either slice the caps into concentric "vertical" cylindrical shells of thickness dr, or into "horizontal" discs of thickness dz.
Please try one of them.​
  • · Replies 19 ·
  • · Replies 24 ·
  • · Replies 16 ·
