How can you make a portable earth connection?
  • Thread starter Thread starter univeruser
    Connection Earth
The discussion revolves around the challenges of creating a portable Earth connection for an AM radio transmitter, particularly in scenarios where traditional grounding methods are impractical. Participants explore various solutions, the necessity of an Earth connection, and alternative antenna designs suitable for short-range transmission.
  • Homework-related
  • One participant suggests burying a ground wire in an earthen pot but finds it ineffective and questions the necessity of an Earth connection for their AM transmitter.
  • Another participant proposes that the radio may work without an Earth connection, indicating that a good antenna design is more critical for effective transmission.
  • Some participants discuss the potential use of a loop antenna, which does not require grounding, as a more efficient and portable option for short-range transmission.
  • Concerns are raised about the size and design limitations of antennas for a spy bug application, with one participant specifically rejecting the loop antenna due to size constraints.
  • There are suggestions to use an oscillator from a clock to create a transmitter, but participants note the challenges of designing a compatible receiver for that frequency.
  • One participant mentions the possibility of using an FM transmitter instead, providing a link to a relevant project while cautioning about the accuracy of the circuit description.
  • Questions arise regarding the interpretation of circuit component values and the feasibility of obtaining necessary components for building the transmitter.
  • Concerns are expressed about interference from local stations on the same frequency, with a participant seeking clarification on frequency regulations for use in different regions.
Participants do not reach a consensus on the necessity of an Earth connection, with multiple competing views on antenna design and transmission methods remaining unresolved.
Limitations include the dependence on specific circuit designs, assumptions about local radio frequency regulations, and the unresolved challenges in building a receiver for the proposed transmitter frequencies.
Individuals interested in amateur radio, electronics projects, and portable communication devices may find this discussion relevant.
univeruser
As it suggests, the problem I face is to how I carry about an Earth connection (for an AM radio transmitter set I made) instead of burying it into the ground? Of course, if I make a radio set, I simply can't carry it about making an Earth connection into the ground.
I have provided a solution to this problem, but seems ineffective: to bury the ground wire into an earthen pot filled with soil.
Does anyone have any other practical solution to this?
By the way, is an Earth connection really required for the radio I am making, at this http://sci-toys.com/scitoys/scitoys/radio/am_transmitter.html" ? In fact, if I remove it, will there be any harm? I suppose the range will become shorter, but the transmission distance I require is only two or three metres at the longest. So does that mean I can remove the Earth connection?
It will probably work OK without the Earth connection. Soil in a pot will not do anything.
An efficient antenna at this frequency would be a half wave dipole, a quarter wave above the ground.
That would be 150 meters long and 75 meters above the ground (492 ft long and 246 ft high).
A less efficient antenna would be a quarter wave long (246 ft) mounted vertically with a very good ground connection.
Since you are not going to do either of these, the longer you make the antenna wire, the better it will work. Do not exceed 3 ft of wire or you may cause interference to AM broadcast stations. Make it just long enough to cover the short distance you need.
First, though, check that there is no local broadcast station on exactly 1000 KHz or whatever frequency is marked on the oscillator.
Check the voltage required for the oscillator unit. Most of these are only for 5 volts so you could damage it with 9 volts. You could probably use 3 AA cells to get 4.5 volts and that would work OK.
I have seen that circuit before and someone claimed the sound was distorted from it.
You don need any earthing for such electronic circuits.
However, The protection system to be used depends on the types of faults occur would in the circuit. In your case the fault type would only be short circuit due to power supply, so u hve to use a few fuses for diodes, transistor (if any) to protect your transmitter.
Have you considered using a loop antenna rather than a monopole? A loop doesn't need an Earth. If you are only needing a link of a few metres, it may be more effective and more convenient. There were many such designs in the past and could be conveniently made using ribbon cable so save actually winding multiple turns. (Join red to orange, orange to yellow, yellow to green etc and then use the first and last colours as your connections - giving you one turn for each colour / strand) The (square loop) antenna can be held in shape by a cross of wood which is easily folded up for transporting.
Take a look at old HAM radio books. Just because the people in the photos wear tank tops and have funny haircuts and their equipment uses valves doesn't mean that the antenna is also a joke. Look into it - you can forget about the need for an Earth that way and you may get very good performance for an antenna which is always going to be a tiny fraction of a wavelength..
No, I can't use a loop antenna, taking into consideration the minimum diameter size and circumference thickness. In fact, I am making a spy bug. So, keeping in mind that a smaller size would be better, could I receive a schematic on how to make a AM transmitter using the oscillator from a clock?
The oscillator in a clock is usually about 32768 Hz and you could make a transmitter out of one, but the problem would be that you would then have to design and build a receiver for that frequency. They do exist but you are not likely to have one.
A much better approach would be to use an FM transmitter on about 95 MHz.
I would suggest something like this:
http://www.electronics-lab.com/projects/rf/002/index.html
However beware that the description of how the oscillator works is nonsense.
The circuit looks OK though.
There are dozens of similar circuits around. The dimensions of the oscillator coil are very important and they determine the final frequency.
You would receive the signal on a commercial FM receiver.
What'cha going to use the spy bug for?
And think about it, a spy bug using radio transmission at 1MHz... as you are finding out, the antenna issue is pretty much a non-starter. Even the FM transmission band is problematic for making something small. There are much better ways to make spy bugs, but of course we can't talk about those here on the PF. (Quiz question -- why not?)
http://www.electronics-lab.com/projects/rf/002/davidtx.gif
When you look at this image, what is referred to by "4u7"? 4 μF? And what about 4k7? Does that mean seven 4000 Ω resistors?
Secondly, I believe sci-toys.com contains information on how to make an AM receiver. I could settle for a longer range FM transmitter, but the difficulty in obtaining the components precisely tuned to the specifications makes it difficult to obtain. Does anyone know of any place online where you can get the components?
And finally, setting apart construction and other issues, will I get any reception of my transmitter if there is another local station on 95 MHz, provided the distance is lesser than 20 m? Take a look at the list of stations at where I live (http://www.asiawaves.net/india/delhi-radio.htm".
If to ensure that I can use my device everywhere in India and worldwide, the frequency of the transmitter must either be below 80 MHz (there are stations in the UAE above 82 MHz, I don't know about the rest of the world) or above 106 MHz. If I'm correct, please try and change the specifications of the schematic given (atleast as to work in Delhi) . If wrong, I hope someone will come by to correct me.
In reply to berkeman's last post, I think that a spy bug need not be necessarily small enough to be hidden, but can be big and even hidden in a toy duck, or so on.
When drawing circuits, the value of the components is sometimes written with the modifier placed where the decimal point would be.
Thus 4K7 refers to 4.7 K or 4700 ohms. 5u6 would be 5.6 uF. 3R9 refers to 3.9 ohms
This is considered less likely to be misunderstood.
This author used 3.3 p instead of 3p3 though, for 3.3 pF
You would have to make the 15 pF capacitor variable to avoid conflict with another station.
So, you could find a clear spot between the commercial stations and tune until you can hear it.
This is a very low powered transmitter, but you have an obligation to avoid transmitting outside your own property. Also most countries regard eavesdropping as illegal invasion of privacy, so you would have to consider what would happen if you tried anything like that.
Forget any ideas about transmitting worldwide with such devices or taking something like that to another country. You have to obey the laws of your country and other countries.
If you want to learn about electronics by building such a device, that is fine, but you won't get much help if you are going to behave illegally.
You're right, by building this I am simply trying to understand more of electronics. Moreover, as I now know from you that spying is illegal, I could use this circuit simply as a wireless microphone, and so on.
And by the way, is it illegal to interfere with the reception of another station at the same frequency, and that too if only on my radio receiver set?
If you interfere with your own radio, you don't know if you are interfering with someone else's radio.
So, if you make the capacitor across the coil a small variable trimmer capacitor, you can set the frequency to somewhere between the stations that are normally there.
Then you won't interfere with anyone. That doesn't make it legal, but within your own property it should not be a problem.
If you get it going, take your radio for a walk and see how far the signal is getting.
Stay legal. It is the only way.
You could use the - (negative) end of a battery. that what it is referred to in a schematic.
Neither end of a battery is, inherently, an 'Earth' connection. Sometimes the positive or negative battery terminal may be connected TO Earth but that is a different matter.
If you want a 'good' Earth for the purposes of launching a good radio signal then you need to promote currents flowing literally in the ground (for a medium frequency signal, at least). Connecting to the Earth network in your home is quite effective - or to a water pipe (they are all bonded together in modern houses).
But, if you are operating illegally, you really don't want to launch interference all over the locality. You want a short range, inefficiently launched, wave which just manages to get as far as your receiver and no further. Any thing will do, basically for your Earth- even just another length of wire, which turns your system into a 'badly fed dipole' - that's fine.
okay then so try this,
charge a capacitor then connect the ground to the negative end of the capacitor and the extra electrons will go in the capacitor. That's what the Earth does: it accepts extra electrons. But on the downside, it only lasts for a few seconds. But if you mean portable as in carrying it in a car then you can use a big capacitor array. If you don't want to get so complicated, then you can use something as simple as a coil antenna.
Not many electrons will "go" anywhere. The capacity of the capacitor (I'm assuming your capacitor is of significant size) will be far higher than the capacity of the positive plate to Earth (which will be in the order of a few pF) . The charge will be shared between the capacity between what is, in effect, two capacitors connected in parallel. The charge will flow in a few nanoseconds, actually, before balance is reached.
The positive end is not supposed to be connected to ground but it doesn't matter because a capacitor has no internal connection.
I also meant to use the tuna-can sized capacitors: the one that is about 1 farad
to the person who added this thread,
read the 5th paragraph under "using the transmitter" in your link.
i read as:
Without any connection to an antenna or a good GROUND CONNECTION, the transmitter will only transmit to a receiver A FEW INCHES AWAY. To get better range, clip the ground wire to a good ground, such as a cold water pipe, and the antenna to a long wire, like the one we used for the crystal radio.
That is: the transmitter would have decreased range but would still work
As far as RF would be concerned, the capacitor would be like a piece of wire - what would be achieved by its presence in the circuit? How would it 'encourage' currents to flow in the Earth?
i am not talking about the earth, i am talking about the current flowing into one of the capacitance plates
This thread seems to have split.
Yes, I think we agree that the best antenna for MF will use an Earth connection, really to the ground. Without it, you have an unbalanced, very short, dipole which is a poor radiator. I probably repeated much what had already been said.
The other issue of using a capacitor is very questionable but, as the proposed 'experiment' wasn't really described fully, it is hard to see what was really meant by it. What I can say is that a capacitor will never fulfill the function of an RF 'Earth Connection' - which was what the OP was about.
Perhaps a bit more detail about how the "1 F" capacitor would be connected . . ? (A diagram would be less easy to misinterpret)
here is a diagram
It's just like I thought- you've got the wrong end of the stick about what would happen with this capacitor. Capacitor circuits are not as straightforward as they may seem.
Firstly, any charge that already exists on the capacitor will make no difference because we are dealing with an alternating signal, so the battery could have no effect whatever the subsequent rights and wrongs.
Secondly, you suggest that the charge existing on the capacitor plates can be affected by the potential on the transmitter Earth terminal. The only way for current to flow out of or into the transmitter Earth terminal is for a Net charge to flow. The only way that this could happen is for there to be a PD across the plates. Just assume that a tiny charge moves onto one plate from the transmitter. This will cause a slight change in PD across the capacitor. BUT this charge will increase the Potential of the other plate wrt the 'real Earth'.
Now, we all know that Q = CV
or V = Q/C
The the capacity, to Earth, of the remote side of the capacitor is very small (a matter of a few pF and, comparing this with your 1F capacitor, it is minuscule. The Potential wrt to Earth is 'shared' by the two capacitors in series. Virtually the whole of the potential that the Tx Earth terminal develops will be dropped across the few pF, which are in series with the big C and the current passed will be limited by that high reactance - it would be as if the 1F capacitor just wasn't there or was replaced, as I said earlier, by a piece of wire. The only way to get a lot of Earth current to flow out of the Tx terminal is either to have a low Impedance path in the form of a good DC connection or a very high value of capacitative coupling (a 'fat capacitor' in series with a good DC connection).
To launch a good wave in the absence of an Earth connection, you need a dipole which presents a 'balanced' load to the transmitter or a large 'Earth plane' or some big structure which needs to have dimensions of, ideally, about 1/4 wavelength radius.
  • · Replies 17 ·
10K
  • · Replies 27 ·
  • · Replies 16 ·
