Young's modulus in microscopic terms
The discussion focuses on deriving Young's modulus (Y) at the microscopic level using the force-separation curve for adjacent atoms in a solid. The formula established is Y = - (1/x_0) (df/dx) | (x=x_0), where x_0 represents the equilibrium separation of atoms. The force function f(x) is defined as f(x) = - (A/x)^7 + (B/x)^13, with A and B set to 1 angstrom (1E-10 m). The relationship between tensile stress and strain is expressed as E = F L_0 / (A_0 ΔL), indicating that Y is the gradient of the stress-strain graph.
  • Understanding of Young's modulus and its significance in material science
  • Familiarity with force-separation curves in atomic physics
  • Knowledge of tensile stress and strain calculations
  • Basic grasp of differential calculus for interpreting derivatives
  • Explore the derivation of Young's modulus from atomic interactions in solids
  • Study the implications of the Lennard-Jones potential in force-separation relationships
  • Investigate the relationship between atomic bond lengths and Young's modulus in different materials
  • Learn about the application of differential calculus in material deformation analysis
Students and researchers in materials science, physicists studying atomic interactions, and engineers focusing on material properties and stress analysis.
Mathsboi
By considering the force-separation curve for two adjacent atoms in a solid, f(x), show that the Young’s modulus can be expressed on the microscopic scale as:
[tex]Y = - \frac{1}{x_0} \frac{df}{dx}\right| |_{x=x_0}[/tex]
(the | is meant to go allt he way form the top to bottom of df/dx)
where [tex]x_0[/tex] is the equilibrium separation of the atoms
[tex]f(x) = - \left(\frac{A}{x}\right)^7 + \left(\frac{B}{x}\right)^{13}[/tex]
(I'm assuming A and B should be 1 angstrom so 1E-10m)
[tex]x_0[/tex] is found by doing f(x).dx = 0 to find where f(x) crosses the x axis.
[tex]E \equiv \frac{\mbox {tensile stress}}{\mbox {tensile strain}} = \frac{\sigma}{\varepsilon}= \frac{F/A_0}{\Delta L/L_0} = \frac{F L_0} {A_0 \Delta L}[/tex]
Y is the gradient of stress/straing graph
hmmmm
I can't exactly read your equations but a long time ago I remember doing an analysis based on a typical diamond lattice structure whereby you could show that Posson's ration came out correctly ( approximatley 1/3) if you assumed that the bond lengths stayed the same and only the bond angles were deformed.
hmmmm
What's [itex]E =F L_0/A_0 \Delta L[/itex] in differential form? What's a reasonable estimate for [itex]A_0[/itex] on the atomic scale?
  • · Replies 23 ·
  • · Replies 16 ·
15K
29K
14K
