Method of Discs/Washers and Cylinderical Shells
  • Thread starter Thread starter trogdor5
    Method
The discussion focuses on calculating volumes of solids of revolution using the methods of discs/washers and cylindrical shells. Specific problems include finding volumes when regions defined by functions such as y=√x and x=y² are revolved around lines like x=9 and y=-1. The key takeaway is the adjustment of the function in the integral based on the axis of rotation, specifically altering the variable in the formula for cylindrical shells, represented as 2π∫x*f(x)dx. Participants emphasize the importance of visualizing the problem through sketches to aid understanding.
  • Understanding of calculus concepts, specifically integration.
  • Familiarity with the method of cylindrical shells for volume calculation.
  • Knowledge of functions and their transformations.
  • Ability to sketch graphs for visual problem-solving.
  • Study the method of discs/washers for calculating volumes of solids of revolution.
  • Learn how to apply the cylindrical shells method with various axes of rotation.
  • Explore function transformations and their impact on volume calculations.
  • Practice sketching regions and their revolved solids to enhance visualization skills.
Students and educators in calculus, particularly those focusing on volume calculations of solids of revolution, as well as anyone looking to strengthen their understanding of integration techniques in real-world applications.
trogdor5
There's just something I need cleared up. When rotating around a line that isn't the x or y axis,I'm not quite sure what to do. Here are some problems:
1) Find the volume of the solid that results when the region enclosed by y=√x, y=0, and x=9 is revolved around the line x=9.
2) Find the volume of the solid that results when the region enclosed by x=y² and x=y is revolved about the line y=-1
3) Use cylindrical shells to find the volume of the solid that is generated when the region that is enclosed by y=1/x^3 , x=1, x=2, y=0 is revolved about the line x=-1
I know that with the cylindrical shells the alteration is within the X part of the formula (2π∫x*f(x)dx) but I'm not exactly sure how to alternate the other two. For example, if the function is √x will the thing become √(x+1)^2 or [(√x)+1]^2? If you could just show me how to do each problem, that would solve my problems :) I know you guys aren't supposed to show how to do the problem, but the only way you can answer my questions is with showing mehow to do it :)
Thank you.
Start by drawing a picture.
Hi trogdor5! :smile:
(try using the X2 tag just above the Reply box :wink:)
trogdor5 said:
… For example, if the function is √x will the thing become √(x+1)^2 or [(√x)+1]^2?
If you're changing x, then you're replacing x by x - a, so y = √x becomes y = √(x - a).
If you're changing y, then you're replacing y by y - a, so y = √x becomes y - a = √x.
  • · Replies 16 ·
