Electric force between two point charges
The discussion focuses on calculating the equilibrium separation (d) between two identical point charges (q) suspended from a silk thread of length (L). The derived formula for d, when the angle (θ) is small, is d=(q²L/2πε₀mg)^(1/3). Key equations utilized include F=ma=Eq and the relationship between tension (T), weight (mg), and electric force (qE). The importance of considering tension in the equilibrium of the system is emphasized, leading to the correct formulation of the problem.
  • Understanding of Coulomb's Law and electric force calculations
  • Knowledge of basic mechanics, including tension and equilibrium
  • Familiarity with trigonometric relationships in small-angle approximations
  • Ability to manipulate algebraic equations and solve for variables
  • Study the derivation of Coulomb's Law and its applications in electrostatics
  • Learn about the principles of tension in strings and pendulum systems
  • Explore small-angle approximations in physics and their implications
  • Investigate the relationship between electric fields and forces in charged systems
Students studying physics, particularly those focusing on electrostatics and mechanics, as well as educators looking for practical examples of force equilibrium in charged systems.
slugbunny
Two identical spheres with mass m are hung from silk thread with length L. Each sphere has the same charge, so q1=q2=q. The radius of each sphere is very small compared to the distance between the two spheres, so they may be treated as point charges. Show that if the angle θ is small, the equilibrium separation d between the spheres is
d=(q2L/2πε0mg)1/3
(Hint: If θ is small, tanθ=sinθ)
F=ma=Eq
The masses are hung from thread connected at the same point so that it looks pendulum-esque and possible use of triangles.
Well I started off with this equation
F=mg=Eq
then used symmetry
mg=2Exq
mg=2E sin(θ) q
mg=2q/(4πε0) (1/(1/2d)2) sin(θ) q
and sin(θ)=r/L so I got
mg=2q2/(4πε0) (4/d2) (r/L)
mg=2q2/(πε0d2) (d/2L)
mg=q2/(πε0dL)
and d is...
d=q2/(πε0Lmg)
I'm thinking that I would get the correct d if I lose the 2 from the electric field symmetry and switch the sin(θ) values (L/r instead of r/L), then I would get a d3 and an L in the numerator and it would work fine hahaha.
Thanks for help!
F=mg=Eq
then used symmetry
mg=2Exq
mg=2E sin(θ) q
My first reaction would be "huh"? Who gave you the idea that mg = qE? In fact, the weight and electric force act in perpendicular directions. Clearly there must be another force that balances the system such that it is in equilibrium! That would be tension in the strings. So,
[tex]mg = T \,cos \theta[/tex]
[tex]qE = T\, sin \theta[/tex]
Alright, carry on.
Thanks, I totally forgot about tension U:
So I can solve for T and get
mg=qE cot(θ)
which gets me the right answer! Thanks so so much :)
  • · Replies 18 ·
