Thread Closed
Carnot Engine Theory Question
Share Thread Thread Tools
Jan19-10, 01:26 AM   #1
Note this is more of a coursework question about the theory behind Carnot engines as opposed to an actual homework question.
3. The attempt at a solution
So I am reading the theory behind a Carnot Engine and I am a little confused about the cooling stages of the Carnot cycle. This is steps 3 and 4 called, "Reversible isothermal compression of the gas at the "cold" temperature, TC" and "Isentropic compression of the gas(isentropic work input)" at http://en.wikipedia.org/wiki/Carnot_...e_Carnot_cycle.
From my reading, it seems to be that some work has to be done on the system to return the piston to its lower volume stage. Basically part of the work that was created to push the piston out is used to return the piston back in. Is this a correct understanding?
If so, I am confused when thinking about the following thought experiment. Lets imagine that I had a balloon filled with gas connected to a shaft connected to an object I wanted to apply work on. When I place the balloon in a hot bath the balloon expands and the shaft moves and the object moves. The the shaft pushes the object over a distance and work is done on the object. When I switch out the balloon into cold water, the balloon shrinks and the object moves back. The object is moved by the force applied from the shaft and work is done on the object again. So in the forward cycle and the backward cycle work is being done to push the object. When I move the balloon cold water, I do not need to apply any addition work, but rather work is being done to the object of interest.
I am not sure where my confusion stems. Thanks in advance.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> King Richard III found in 'untidy lozenge-shaped grave'
>> Google Drive sports new view and scan enhancements
>> Researcher admits mistakes in stem cell study
Jan19-10, 03:33 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Quote by tiredryan View Post
Essentially yes. Work has to be done to restore the system back to its initial state, but it doesn't necessarily have to be part of the work output from the earlier part of the process.
If so, I am confused when thinking about the following thought experiment. Let's imagine that I had a balloon filled with gas connected to a shaft connected to an object I wanted to apply work on. When I place the balloon in a hot bath the balloon expands and the shaft moves and the object moves. The shaft pushes the object over a distance and work is done on the object. When I switch out the balloon into cold water, the balloon shrinks and the object moves back. The object is moved by the force applied from the shaft and work is done on the object again. So in the forward cycle and the backward cycle work is being done to push the object. When I move the balloon cold water, I do not need to apply any addition work, but rather work is being done to the object of interest.
It's implied in your description that the object comes to rest in between the two phases. As it decelerates, it's doing work on the gas. Also, when the gas cool, it will contract only if something outside does work. In this case, both the balloon and the outside atmosphere will perform work, and part of the work goes into accelerating the object.
Thread Closed
Thread Tools
Similar Threads for: Carnot Engine Theory Question
Thread Forum Replies
carnot engine Classical Physics 2
The Carnot Engine Introductory Physics Homework 29
Carnot engine Advanced Physics Homework 4
Carnot Engine Introductory Physics Homework 1
Carnot Engine - Carnot Refrigerator Introductory Physics Homework 2
