Wave–particle duality theory question
  • Thread starter Thread starter tiredryan
    Duality Theory
The discussion revolves around wave-particle duality, specifically focusing on the behavior of electrons and photons as described by quantum mechanics. Participants are exploring concepts related to matter waves, de Broglie relations, Schrödinger's equation, and Heisenberg's uncertainty principle.
  • Participants are attempting to understand the implications of wave functions for electrons and photons, questioning the significance of amplitude in matter waves and the ability to determine probabilities of particle localization.
The discussion includes various interpretations of quantum mechanics principles, with some participants questioning the applicability of Schrödinger's equation to photons and the implications of Heisenberg's uncertainty principle. There is an ongoing exploration of differing viewpoints, particularly regarding the nature of wave functions for photons versus electrons.
Some participants express confusion about the limitations of Schrödinger's equation and the nature of probability amplitudes for different particles, indicating a need for clarification on these concepts. References to external sources, such as academic papers and discussions from other threads, are made to support their points.
tiredryan
Note this is more of a coursework understanding question rather than a specific homework question.
I have been reading about matter waves and de Broglie relations which suggest that electrons can act as waves. From wikipedia (http://en.wikipedia.org/wiki/Matter_wave) it suggests that the following is true.
[tex]\lambda = \frac{h}{p}[/tex] and [tex]f = \frac{E}{h}[/tex]
In that article it does not suggest the significance of the amplitude in the matter wave. From the wave–particle duality article (http://en.wikipedia.org/wiki/Wave–particle_duality) it suggests that "upon measuring the location of the particle, the wave-function will randomly "collapse" to a sharply peaked function at some location, with the likelihood of any particular location equal to the squared amplitude of the wave-function there."
If I understand this correctly, the probability of finding an ejected electron along a linear trajectory is not equal along its path, but rather the probability is sinusoidal. At one part of the trajectory, I might have a 100% chance of finding an electron when the amplitude is max and [tex]\lambda[/tex]/4 away there is a 0% chance of finding an electron when the amplitude is zero. This is counterintuitive so I want to check if my reasoning is correct.
Thanks in advance.
PS: For a numerical example, solving the equations for an electron in a 10 kV scanning electron microscope yields a wavelength of 12.3 x 10^-12 m (12.3 pm) as from http://en.wikipedia.org/wiki/Electron_diffraction. If I understand this correctly, as an electron travels in this setup, the probability of finding the electron varies from 0% to 100% sinusoidally with a wavelength of 12.3 x 10^-12 m (12.3 pm).
So I came across another post in which it describes the photon wave function.
https://www.physicsforums.com/showthread.php?t=8698
In that post, arcnets, stated that "I mean it in the following sense: "It's not possible to define any photon wavefunction from which a probability amplitude for spatial localization can be calculated". (Landau-Lifschitz IV, chapter 1, §4.)"
If I understand this correctly, the probability of a photon at any position cannot be determined. However, the probability of an electron at a position can be determined by Schrödinger's equation. Is this correct?
Thanks in advance.
So on a related note I have delved deeper into Schrödinger's equations and came across Heisenberg's uncertainty principle. It seems that Schrödinger's equation applys only to electrons and not photons whereas Heisenberg's uncertainty principle apply to photons and electrons. Are these correct limitations to these theories?
Thanks in advance.
Thanks in advance.
Thanks in advance.
This is totally false. Read the Marcella paper (i.e. don't just read Wikipedia)
http://arxiv.org/ftp/quant-ph/papers/0703/0703126.pdf
Zz.
Thanks for your quick response. I am a new student to physics, and I am still in my introductory physics class. I am trying to understand the paper and your statement, "this is totally false."
From the paper's statement, "because position and momentum are non-commuting observables, a particle passing through slits always has an uncertainty in its y-component of momentum," I am guessing that my statement, "Heisenberg's uncertainty principle applies to photons and electrons," is correct. Or is it false?
I am guessing that the "totally false" statement has to deal with my other statement on Schrödinger's equation. If I understand the paper correctly, then Marcella was able to determine the "calculation for the probability amplitude and its corresponding probability function" using Schrödinger's equations. I am guessing this would mean that Schrödinger's equations applies to both photons and electrons. Correct me if I am wrong here.
Also is this quote by Arcnet citing Landau-Lifschitz posted earlier false? Arcnets, stated that "I mean it in the following sense: "It's not possible to define any photon wavefunction from which a probability amplitude for spatial localization can be calculated". (Landau-Lifschitz IV, chapter 1, §4.)"
Thanks for your response. I'm sorry for my confusion.
Zz.
  • · Replies 36 ·
10K
  • · Replies 41 ·
