How Can I Precisely Bend a Copper Tube for a Total Pressure Probe?
  • Thread starter Thread starter dopeyranger
    Pressure Tube
The discussion revolves around the challenges of bending a copper tube to create a total pressure probe for small-scale wind tunnel testing. Participants explore various techniques and considerations related to the bending process, including the impact of tube diameter, wall thickness, and flow dynamics.
  • One participant notes the difficulty in achieving a small radius bend without damaging the tube and seeks DIY techniques for bending copper tubes.
  • Another participant suggests a rule of thumb for bend radius, recommending it be 3-4 times the tube diameter, while also mentioning that thicker walls may bend more easily.
  • Several participants propose using a coil or filling the tube with a material that can be melted out to prevent deformation during bending.
  • Concerns are raised about using miter bends in instrumentation lines due to potential flow distortion and the introduction of weak points in the tubing.
  • A participant questions the necessity of maintaining laminar flow in the tube and discusses the potential for turbulent flow models to yield accurate pressure measurements.
  • Another participant emphasizes the importance of minimizing recirculation zones in bends to maintain accurate pressure readings.
  • Discussion includes the significance of design aspects such as the probe's nose and flow direction on measurement uncertainty.
Participants express differing views on the best practices for bending tubes and the implications of flow dynamics on pressure measurements. There is no consensus on the optimal bending technique or the necessity of laminar versus turbulent flow considerations.
Participants mention various assumptions regarding tube wall thickness, bend radius, and flow characteristics, but these assumptions remain unresolved and depend on specific conditions of the application.
dopeyranger
Hello
I am attempting to make a total pressure tube/probe to use on small scale wind tunnel testing.
Like a pitot static probe, this total pressure probe has to have a 90 degree bend like an L shape.
I have several copper tubes of around 3 mm OD.
I tried bending them by heating the metal using a bunsen burner, and then bending.
However, I get quite a large radius when bending. If I attempt a small radius (like a proper 90 degree bend) then the tube fails, it ends up having a dent on it at the bend.
Is there anyway I can bend it precisely with a small radius?
It has to be some kind of DIY technique because I do not have any bending tools and neither does the University that I study at. In fact the university does not allow me to use a bunsen burner in the campus due to health and safety so I have to do this at home.
Please help
Regards
Dopey
A rule of thumb is that a tube bend radius should be around 3-4 times the tube diameter. For example, a Ø.50" tube would have a bend radius of 1.5-2.0". Since you are working with copper, you may try to get a bit smaller. This also depends on tube wall thickness. A thicker wall will usually bend nicer than a thin wall. So if you are having trouble, try increasing the wall thickness.
Use a coil wrapped around the tube when you bend it. Most hardware stores sell these as tube bending kits (if you live in the US, check Harborfreight, they have one for $2). The idea is to prevent the tube from deforming radially...
Another approach used (for instruments) is to fill the tube with something that you can melt out (it used to be lead but I guess you could also use tin or maybe even wax). Once the tube is filled (and cold), bend it, then remelt its contents.
Let us know what works.
fill it with sand, or cut it off at a 45 and rotate and solder it together
dr
miter bends are a no no in instrumentation lines.
Yep.
why is that?
is the "rule of thumb" the minimum that the bend can be?
dr
dr dodge said:
why is that?
dr
You want as little flow distortion as possible. A miter will not allow flow to easily make the bend. Usually we aim for a 4D for the bend radius as a starting point. That usually keeps you free from tube bending issues like kinking and flattening as well.
now another question
apparently you are trying to maintain a laminar flow in the tube, but couldn't the "turbulant flow" model be used and potentially get the same or better numbers?
In actuality there really is not "true flow" in the pitot measurement being the tube dead ends in a sensor of some sort.
aren't there some accurate models now based upon turbulant flow that could predict and pressure differential?
dr
It's not so much laminar flow, it's just a constant velocity profile or knowledge of the velocity direction where the probe is located. In weird bends you get all sorts of recirculation zones. You are simply trying to minimize anything like that. It's like what you see in the lower left hand corner of the image
http://www.chengfluid.com/images/meter_runs_2.gif
ok, I understand all that (by the way, very nice diagram, I saved it for future ref)
what I was trying to figure out was:
the desired measurement is a pressure measurement that you are taking.
there is max velocity at the point of entry, and zero velocity at the pressure sensor at the end. so the pressure is a function of the velocity at the point of entry (force) vs area of the opening
some small pressure differential could take place between the opening, and the sensor, but that should be predictable
dr
It's really more important when you get into aspirated probes where there is a constant flow through them. If we're talking a plain old total probe then it doesn't really matter. You still want to avoid miters because they introduce a weak point in the tubing. You really don't want a probe breaking off and going downstream.
Usually the main aspects of uncertainty in the measurements are from the design of the nose, the direction of flow relative to the nose (yaw sensitivity) and the speed of the flow. Once you get into the compressible realm (we usually use around M = .2) you need to worry about measuring pressure behind a bow shock on the nose. You can correct for that but you usually need static pressures as well.
thanks Fred
dr
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 22 ·
