Thread Closed
First order DE, using integrating factor
Share Thread Thread Tools
Jan20-10, 03:38 PM   #1
Hi,
I tried to solve this by using the integrating factor technique
[tex]\begin{cases}
dy/dt +10y = 1 \\
y(1/10) = 2/10
\end{cases}[/tex]
So [tex]p(x) = 10t \rightarrow e^{10t}[/tex]
[tex]e^{10t} \cdot \frac{dy}{dt} + e^{10t} \cdot 10y = e^{10t}[/tex]
This part is confusing to me, i have two different variables y and t.
How do i integrate the left side?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Jan20-10, 03:45 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Quote by James889 View Post
The independent variable in this problem is t. It's playing the role x would usually play.
The point of the integrating factor is to turn the lefthand side into a derivative. In your case, you have
[tex]e^{10t} \cdot \frac{dy}{dt} + e^{10t} \cdot 10y = (e^{10t} y)'[/tex]
You can differentiate [itex]e^{10t} y[/itex] to verify that's the case. So integrating the lefthand side is trivial because you're just integrating a derivative.
Jan20-10, 06:10 PM   #3
Ok,
So after integrating both sides, i have
[tex]e^{10t}\cdot y = \frac{1}{10} e^{10t} +C[/tex]
After inserting applying the initial conditions i get:
[tex] e^{10t} \cdot \frac{1}{10} = \frac{1}{10} e^{10t} +C[/tex]
This gives that the e terms cancel and C = 2/10 but that's incorrect.
Hm, what am i missing here?
Jan20-10, 06:28 PM   #4
Recognitions:
Ok,
You can solve for y to get
[tex]y=\frac{1}{10}+C e^{-10t}[/tex]
A few mistakes in what you did: you didn't substitute a value in for t, and you plugged in the wrong initial value for y. Also, you apparently did the algebra wrong because the exponentials can't cancel.
Jan22-10, 04:19 PM   #5
Quote by vela View Post
Hm, after plugging in the right value for y i get, like you.
[tex]e^1\cdot \frac{2}{10} = \frac{e^1}{10} + C[/tex] which clearly gives C = e/10
But how did you get [tex]e^{-10t}[/tex] ?
That must be from dividing by 2e^10 but why does the variable t reappear when you already plugged in 1/10 ?
Sorry for the ignorance, i suck.
Jan22-10, 10:26 PM   #6
Recognitions:
I divided both sides of the equation by [itex]e^{10t}[/itex] to solve for y. All you have to do now is take the value of C you found and plug it back into the solution.
Thread Closed
Thread Tools
Similar Threads for: First order DE, using integrating factor
Thread Forum Replies
First order linear ODE-integrating factor has absolute value in it Calculus & Beyond Homework 7
Help with integrating factor Calculus & Beyond Homework 5
Integrating Factor Differential Equations 4
Integrating Factor Calculus & Beyond Homework 2
Integrating Factor ODE Fix Calculus & Beyond Homework 1
