Definition of Poisson Bracket: {f,g}
The Poisson bracket is defined as either {f,g} = df/dp.dg/dq - df/dq.dg/dp or {f,g} = df/dq.dg/dp - df/dp.dg/dq. Both definitions are valid, with the choice depending on the author's preference. However, the second definition is more commonly accepted in literature and is recommended for use. Understanding this distinction is crucial for accurate application in Hamiltonian mechanics.
  • Familiarity with Hamiltonian mechanics
  • Understanding of differential calculus
  • Knowledge of classical mechanics terminology
  • Experience with mathematical notation in physics
  • Research the applications of Poisson brackets in Hamiltonian dynamics
  • Study the implications of different definitions in theoretical physics
  • Learn about symplectic geometry and its relation to Poisson brackets
  • Explore the role of Poisson brackets in statistical mechanics
This discussion is beneficial for physicists, mathematicians, and students studying classical mechanics or Hamiltonian systems, particularly those interested in the mathematical foundations of physics.
Pyroadept
Hi, what is the correct definition for a Poisson bracket?
Some books say it is:
but others say it is:
One is the other multiplied by -1.
Which is the correct definition?
Thanks for any help.
You CAN use either the first definition or the other one and this only depends on author's style though if I were you, I would take the second one for granted in being more common and true.
AB
