Tensor of Inertia for Half Disk: Calc Angular Momentum
  • Thread starter Thread starter springo
    Inertia Tensor
The discussion focuses on calculating the tensor of inertia for a half disk with mass M and deriving the angular momentum along a specified axis. The moment of inertia tensor for the half disk is established as I = \begin{bmatrix} \frac{MR^{2}}{2} & 0 & 0 \\ 0 & \frac{MR^{2}}{4} & 0 \\ 0 & 0 & \frac{MR^{2}}{2} \end{bmatrix}. The application of Steiner's theorem is discussed to adjust the tensor for the half disk, resulting in a new tensor I' = \begin{bmatrix} \frac{MR^{2}}{2} & 0 & 0 \\ 0 & \frac{5MR^{2}}{4} & 0 \\ 0 & 0 & \frac{3MR^{2}}{2} \end{bmatrix}. However, the user expresses uncertainty regarding the correctness of this tensor as it leads to zero variation in angular momentum at constant rotation speed.
  • Understanding of moment of inertia and its tensor representation
  • Familiarity with Steiner's theorem (parallel axis theorem)
  • Basic knowledge of angular momentum concepts
  • Proficiency in matrix operations and manipulations
  • Study the application of Steiner's theorem in detail
  • Learn about angular momentum calculations for rigid bodies
  • Explore the derivation of moment of inertia tensors for various shapes
  • Investigate the implications of zero angular momentum variation in physical systems
Students in physics, particularly those studying mechanics, as well as engineers and researchers working with rotational dynamics and inertia calculations.
springo
Find the tensor of inertia for a half disk with mass M and then use that to get the angular momentum along the axis in the figure.
http://img138.imageshack.us/img138/5312/problemr.png
Moment of inertia for the whole disk (with mass 2M)
[tex]\begin{bmatrix}<br /> \frac{MR^{2}}{2} & 0 & 0 \\ <br /> 0 & \frac{MR^{2}}{2} & 0 \\ <br /> 0 & 0 & MR^{2}<br /> \end{bmatrix}[/tex]
For the tensor:
[tex]\begin{bmatrix}<br /> \frac{MR^{2}}{2} & 0 & 0 \\ <br /> 0 & \frac{MR^{2}}{4} & 0 \\ <br /> 0 & 0 & \frac{MR^{2}}{2}<br /> \end{bmatrix}[/tex]
And the moment of inertia... I think I should apply Steiner's theorem, but I'm not quite sure how to apply it on a tensor.
Thanks for your help.
See:
http://en.wikipedia.org/wiki/Parallel_axis_theorem"
You take the displacement vector [tex]\mathbf{a}[/tex]
(written as a column vector) and form the matrix [tex]\mathbf{a}\mathbf{a}^\top[/tex]
The new moment of inertia tensor is then:
[tex]\mathbf{I}'=\mathbf{I} + M(|a|^2\mathbf{1} -\mathbf{a}\mathbf{a}^\top)[/tex]
[edited above, forgot the mass!]
Thanks.
OK, so assuming my "attempt at a solution" tensor was right, I get to the following tensor:
[tex] \begin{bmatrix}<br /> \frac{MR^{2}}{2} & 0 & 0 \\ <br /> 0 & \frac{MR^{2}}{4} & 0 \\ <br /> 0 & 0 & \frac{MR^{2}}{2}<br /> \end{bmatrix}<br /> +\begin{bmatrix}<br /> 0 & 0 & 0 \\ <br /> 0 & MR^{2} & 0 \\ <br /> 0 & 0 & MR^{2}<br /> \end{bmatrix}<br /> =\begin{bmatrix}<br /> \frac{MR^{2}}{2} & 0 & 0 \\ <br /> 0 & \frac{5MR^{2}}{4} & 0 \\ <br /> 0 & 0 & \frac{3MR^{2}}{2}<br /> \end{bmatrix}[/tex]
I think this can't be right because then when I try to find variation in the angular momentum (at constant rotation speed), I get 0.
18K
