What is the wave speed in a brass wire
The wave speed in a brass wire can be calculated using the formula v = √(T/μ), where T is the tension and μ is the mass per unit length. For a brass wire with a radius of 4.65×10-4 m and a tension of 128 N, the mass per unit length μ is determined by multiplying the density of brass (8.60×103 kg/m3) by the cross-sectional area of the wire. The cross-sectional area is calculated as A = πr2, leading to a complete solution for wave speed.
  • Understanding of wave mechanics and wave speed calculations
  • Familiarity with the properties of materials, specifically brass
  • Knowledge of basic geometry for calculating area
  • Ability to manipulate and solve algebraic equations
  • Calculate the cross-sectional area of the brass wire using A = πr2
  • Determine the mass per unit length μ using μ = Density × Area
  • Apply the wave speed formula v = √(T/μ) to find the wave speed
  • Explore the effects of tension and density on wave speed in different materials
Students studying physics, particularly those focusing on wave mechanics, as well as engineers and material scientists interested in the properties of brass and wave propagation in solid materials.
Batman354
What is the wave speed in a brass wire with a radius of 4.65×10-4 m stretched with a tension of 128 N? The density of brass is 8.60×103 kg/m^3.
v=square root of T/u
I have already found the cross sectional area but am unsure of what to do from there.
Hi Batman345, welcome to PF.
Mass per unit length μ =Density*Area
