New Reply
Faraday's magnetic induction
Share Thread Thread Tools
Jan24-10, 10:43 PM   #1
Hi everyone...
While going through some texts.. At one place i found that in faraday's law of magnetic induction,
>a time varying magnetic field induces an electric field..
And, >a spatially varying electric field induces a magnetic field..
Which one of these is correct? I know of former, but by any chance, second one can also be correct??
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Jan24-10, 10:58 PM   #2
A time varying magnetic field results in a spatially varying electric field and visa versa.
Now, as long as the electric field varies spatially, then it must be nonzero somewhere, therefore we obtain your first statement.
Thinking that one field causes the other field is incorrect. That is, there is no cause and effect pairing. The word 'induce' is basically a grammatical error with historical roots.
There is one field, called the electromagnetic field tensor, that has various components. These components are the electric and magnetic field strengths.
Jan24-10, 11:14 PM   #3
Ok..
Suppose i have an electric and a magnetic field (constant).. [faraday law also shows that a spatially non varying E leads to a temporally non varying B]..
If i vary B in time.. This will lead to a spatially varying E.. So-
will this E add to new originally existing E field... Or, the it is the originally existing field that will start varying... ?
Jan26-10, 03:22 AM   #4
Recognitions:
Gold Membership Gold Member
Quote by !kx! View Post
Ok..
They will just add up, classical electrodynamics follows linear superposition.
Jan26-10, 03:34 AM   #5
Quote by Born2bwire View Post
ok. If I have a conducting wire in above configuration.. with a field E and a field B. Current flows due to E; if B starts to change.. then the current will increase (or decrease), due to the field (E + E') [or, (E - E')].. {E' is induced electric field due to B}.
Am i correct?
Jan26-10, 06:04 AM   #6
Recognitions:
That would depend but on the whole I would say no. First, the orientation of the magnetic field that is varying will dictate the orientation of the varying electric field. This electric field could be oriented in such a way that it does not impact the flow of current in your wire.
Second, since we now have time-varying fields, we can only induce time-varying currents. The resulting fields are electromagnetic waves, and they will induce currents on the surface of the wire (assuming a perfect conductor). These currents will simply add to whatever current is already impressed upon the wire. If you can somehow induce a wave that is of the same frequency and will induce currents that are perfectly out of phase with the applied currents, then you could cancel out the applied currents. However, this really isn't feasible, and so you can filter out whatever induced signals are on the wire and regain your original signal should you wish.
Jan26-10, 06:20 AM   #7
ok.. i get sm idea..
thx..
this may be a little off the topic, but do you know if a plasma, in stable state, has any net electric field?
Jan26-10, 08:29 AM   #8
Recognitions:
thx..
Depends on what you mean by stable. I could have a non-neutral plasma that could be put into a steady-state by simply confining it in a box. There will still be net forces exerting in the plasma (manifested as a pressure on the box) and there will be a net electric field simply due to the non-neutrality of the plasma but the plasma itself will not change. If the plasma was neutral to begin with, then it will arrange itself to be more or less electrically neutral although you will have little packets of quasi-neutral regions pop up here and there from various fluctuations in the plasma. For the most part it would be electrically neutral.
Jan26-10, 08:32 AM   #9
ok.. thanx for the help..
Jan26-10, 10:12 AM   #10
The second one is not generally correct, nor is it implicit in Maxwell's equations. For example, an electrostatic field generally varies in space; yet there may be no magnetic field at all.
Jan26-10, 10:47 AM   #11
Quote by GRDixon View Post
I'm in basic agreement with you. In a sense I understand and agree with the previous points. Particularly, I like Phrak's comment "There is one field, called the electromagnetic field tensor". However, the statement "a spatially varying electric field induces a magnetic field" does not seem worded correctly to me. Aside from Phrak's point about the word "induces", we get into questions of reference frame. For example, a static, spatially varying electric field, due to a point charge, has no magnetic field in a reference frame moving with the charge. If one moves relative to the charge, then the charge looks like a current, and there is a magnetic field. So, in a sense, the magnetic field is there, but it is also not there if you are not moving relative to the charge.
My point is that any statement like this should make sense to a very educated person who understands the tensor/relativity aspects of field theory. But, it should also make sense to an undergraduate student in a first semester of EM field theory. That statement will confuse the heck out of the uninitiated student.
Jan27-10, 08:51 AM   #12
Quote by elect_eng View Post
This seems pretty interesting..
Jan27-10, 10:13 PM   #13
Yeah. I missed that. Which begs the question what is the form of the electric field that is associated with a time varying magnetic field?
It turns out to be non-zero curl. Grad x E + dB/dt = 0, in natural units. This is the Maxwell-Faraday equation. So where ever you can factor-out a nonzero curl(E) from the field, there will be an associated changing B field.
The corollary is that wherever one finds a time changing B field, there is a circuital electric field. The electric field doesn't terminate on charge--or, at least not all of it, but wraps back on itself.
Jan28-10, 09:32 AM   #14
Greetings,
I think the earlier part of this is getting close to some questions I've had.
In Feynman's lectures - vol. 2 either chap 19, 21 or 23 - I think 23 (I'm at work and don't have the lectures here), Feynman shows in a capacitor that a changing E-Field induces a B-field, then he shows that the B-field induces a new E-Field (he calculates the E-field) and then adds the 2 E-fields together. Well he says that "new" E-field creates a new B-field - he calculates that new B and adds the two B's together and so on.
He does 3 or so to see the pattern.
He ends up showing the E-field and B-field is this complicated expression involving a Bessel function.
I had under-grad electromagnetics - junior and senior level and this was never mentioned.
This Feynman lecture and results does not seem obvious to me -
Is this thread getting close to this topic of Feynman's lecture?
Can you elaborate further on this?
Why was it not mentioned in electrodynamics (under-grad level at least)?
It seems so interestesting but I never would have known to go there, I would have stopped at the first calculation.
Thanks
-Sparky
Jan30-10, 10:56 AM   #15
Is there any characteristic difference between the magnetic field produced by, say some current carrying wire, and that existing in free space, in form of an EM wave...???
Jan30-10, 01:14 PM   #16
The wire induces a B field via Ampere's Law. It can be magnetostatic. The B field in a wave is induced by a time-varying E field and is not static (in time). However, when the E field between the plates of a capacitor is varied, it induces a B field much as the time-varying E field in an electromagnetic wave does. Maxwell suggested that the time-varying E field between the capacitor plates was proportional to a "Displacement Current" flowing out of one plate and into the other. These Displacement Currents theoretically induce B fields a la Ampere's Law, quite as currents of free charges do.
Jan30-10, 09:04 PM   #17
As elect_eng earlier said, that me observing the magnetic field due to a current will depend on my motion.. So, I could have said that the magnetic field, existing or not, will depend on the observer's state of motion..
But since, the magnetic field in an EM wave is not the same as that due to a current carrying wire, I can't say the same thing for this field.. Right??
New Reply
Thread Tools
Similar Threads for: Faraday's magnetic induction
Thread Forum Replies
Faraday's Law of Induction Introductory Physics Homework 1
Faraday's Law of Induction Advanced Physics Homework 5
Faraday's Law of Induction Introductory Physics Homework 11
Magnetic induction, Faraday's law and the likes Classical Physics 4
