Checking whether a curve is a parabola or not
  • Context: Undergrad
  • Thread starter Thread starter adelz
    Curve Parabola
This discussion focuses on methods to determine if a curve in 3D space is a parabola, particularly for assessing the structural abilities of hypar surfaces in parametric design. Two primary approaches are suggested: using three points to derive a parabola's equation and testing additional points for fit, or applying least squares analysis to fit a second-order polynomial to the points. Visual plotting is recommended to enhance understanding of the curve's characteristics.
  • Understanding of parametric design techniques
  • Familiarity with 3D coordinate systems (x, y, z)
  • Knowledge of polynomial equations, specifically second-order polynomials
  • Experience with least squares analysis for curve fitting
  • Research methods for deriving equations of parabolas from points
  • Learn about least squares fitting techniques in data analysis
  • Explore visualization tools for plotting curves in 3D space
  • Investigate parametric design software that supports structural analysis
Engineers, architects, and designers involved in structural analysis and parametric design, particularly those working with curves and surfaces in 3D modeling.
adelz
Hi everyone,
I'm generating some hypar surfaces for a structure through parametric design techniques. In order to assess their structural abilities, I am finding their cross section curves and would like to check whether they are parabolas or not.
So, in 3d space, (x,y,z) I have a curve - I can find the coordinates of n number of points along it. I cannot necessarily find the vertex as I do not know what portion of a parabola the curve might be .. My question is, can anyone help me figure out a way to check whether the curve itself is a parabola (or part of a parabola) or not?
Thanks!
Since you are dealing with a cross section, the implication is that the points are planar, which means you should be able to express the points as x-y coordinates. Once you have that, I can think of a couple of approaches:
1. Use 3 of the points (e.g. 2 end points and a middle) to determine the equation of a parabola that passes through the 3 points, then test the n-3 points to see how close they are to the analytical curve.
2. Slightly different from #1, perform least squares analysis on the n points to determine the coefficients of a 2nd order polynomial fitting function. The value of residual will give you can idea of how close the points fit a parabola.
In both cases, a visual plot is always helpful.
16K
  • · Replies 25 ·
