Register to reply
Battery Powered Nichrome Heating Element (80 Degrees)
by ryancanulla
Tags: battery, degrees, element, heating, nichrome, powered
Share this thread:
ryancanulla
#1
Jan25-10, 11:51 AM
P: 2
Hi there,
I have been doing research on a lil private project of my own, and am looking for some help.
Would it make sense to use nichrome wire to build a heating element that will heat to 80-100 degrees? It seems that nichrome is great for heating way way past that temperature. I want to run this initial test off of battery power.
Thanks in advance for any insights!
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
jmatejka
#2
Jan25-10, 01:02 PM
P: 128
More information needed? Fahrenheit?,Open loop control?, closed loop? How about the wrap for pipes that helps keep them from freezing, open loop-constant temp, would that work?
ryancanulla
#3
Jan25-10, 01:14 PM
P: 2
Hi there,
I'm looking to heat a 4in X 4in pad to 80 degrees F. Sorry I am a real newbie in this area, and trying to prototype a battery powered heating element.
I'm trying to apply this at a very small scale to not cause any6 bodily harm, start fires etc. Any help is greatly appreciated!
Steve1975
#4
Feb1-10, 04:05 AM
P: 1
Hello. I am trying to create a heating element which can reach 200f withing 2 seconds, is no bigger then 1/4" in diameter, can withstand repeated heating and cooling cycles for long periods of time, and is immersible in propylene glycol. I am shooting for the 3.7v to 7.4v area. Those are the only constraints.
I have achieved this with nichrome coils, but the lifespan is simply to short.
Any ideas????
Register to reply
Related Discussions
Target temperature of nichrome heating element Electrical Engineering 9
The Heating of Nichrome Wire in a toaster Introductory Physics Homework 6
Human powered still - Nichrome wire Electrical Engineering 6
