Marginal Distribution of X w/ Lambda Parameter: Probability Help
The discussion revolves around finding the marginal distribution of a Poisson random variable X with a parameter λ that follows an exponential distribution. Participants are exploring the application of probability theory, specifically the integration of dependent distributions and the use of Bayes' rule.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant expresses uncertainty about their probability skills and seeks assistance with the marginal distribution of X and the conditional density of λ given X.
  • Another participant suggests using Bayes' rule and asks about the results obtained so far.
  • A participant shares their attempt at calculating the marginal distribution using an integral, but initially doubts its correctness due to the complexity of the output from Mathematica.
  • The same participant later revises their stance, indicating that the integral is manageable with some manipulation.
There is no consensus on the correctness of the initial approach to the integral, and participants are still exploring the problem without a clear resolution.
Participants have not fully resolved the mathematical steps involved in the integration, and there may be dependencies on specific definitions or assumptions regarding the distributions.
ryzeg
I am a little shaky on my probability, so bear with me if this is a dumb question...
Anyway, these two random variables are given:
X : Poisson ([tex]\lambda[/tex])
[tex]\lambda[/tex] : Exponential ([tex]\theta[/tex])
And I simply need the marginal distribution of X and the conditional density for [tex]\lambda[/tex] given a value for X
I have all the equations for dependent distributions, but do not know how to apply them to this ostensibly easy problem...
Any help?
You'll need Bayes' rule for this. What results have you got so far?
I was doing this, but I think it is wrong:
[tex] f_X(x) = \int^{\lambda=\infty}_{\lambda=0} \frac{\lambda^{x}}{x!} e^{-\lambda} \times \theta e^{-\theta \lambda} d \lambda[/tex]
Plugging this integral into Mathematica gives a really nasty output with a incomplete gamma function, and my TI-89T cannot evaluate it.
I take that back; the integral is doable with a little manipulation. Damn machines...
