| Thread Closed |
Finding x when Elastic Potential Energy equals Kinetic Energy |
Share Thread | Thread Tools |
| Jan25-10, 09:05 PM | #1 |
Here's the problem I've been working on:
"A mass is oscillating with amplitude A at the end of a spring. How far (in terms of A) is this mass from the equilibrium position of the spring when the elastic potential energy equals the kinetic energy?" Now I know that Us = 0.5*k*x^2 and K = 0.5*m*v^2. I first thought that the answer would be .5 (half of A) since that would be halfway between fully stretched and at equilibrium, then I thought maybe at equilibrium, but neither worked. I also then tried to set the two equations equal to one another, but can't go anywhere with this. Any ideas? This is a fairly simple question that is completely stumping me... 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Jan25-10, 09:19 PM | #2 |
| Jan25-10, 09:29 PM | #3 |
Ok, so I tried setting 0.5kx^2 = 0.5mv^2, and end up with x = sqrt(mv/k), which tells me nothing because I don't know v, m, or k. I tried using conservation of mechanical energy by saying MEi = 0.5kxi^2 + 0 (which means there's only potential energy in the system) and MEf = 0.5kxf^2 + 0.5mvf^2, and setting MEi = MEf, but still got nowhere... grr...
| Jan26-10, 05:25 AM | #4 |
When you use mechanical energy conservation, you say that the sum of kinetic plus potential energy at one point is the same as kinetic plus potential energy at another point. I am sure you know this but you are not applying it correctly.
When the mechanical energy is all in the potential energy form at displacement x = A, you have ME = (1/2)kA2 where A is the amplitude. When the kinetic energy is equal to the potential energy at displacement x < A ME = (1/2)kx2 + (1/2)mv2 Now you set KE = PE in the last expression and demand that the ME at displacement x be the same as the ME at x = A. That's mechanical energy conservation. |
| Thread Closed |
| Tags |
| kinetic energy, potential energy |
| Thread Tools | |
Similar Threads for: Finding x when Elastic Potential Energy equals Kinetic Energy
| Work-Energy Theorum: Spring potential energy vs Kinetic Energy | Introductory Physics Homework | 4 | ||
| Elastic Potential Energy- finding spring constant | Introductory Physics Homework | 3 | ||
| Potential Elastic Energy & Kinetic Energy | Introductory Physics Homework | 6 | ||
| Finding kinetic energy retained by an object after an elastic head-on collision | Introductory Physics Homework | 1 | ||
| [SOLVED] Mechanical Energy vs Potential Energy & Kinetic Energy | Introductory Physics Homework | 3 | ||
