Heat of fusion of water ice and dry ice (CO2) - need some insight
The forum discussion focuses on the heat of fusion of ice and the heat of sublimation of dry ice (CO2) as measured in calorimetry experiments. The calculated heat of fusion for ice was 333.3 J/g, closely aligning with the accepted value of 334 J/g, while a second measurement yielded a lower value of 292.9 J/g, raising questions about potential experimental errors. The heat of sublimation for dry ice was calculated at 663.3 J/g, significantly higher than the accepted value of 571 J/g, prompting inquiries into the effects of evaporation on energy absorption. The discussion emphasizes the importance of considering heat loss to the environment and the calorimeter's effective mass in such experiments.
  • Understanding of calorimetry principles
  • Familiarity with heat transfer concepts
  • Knowledge of phase changes and latent heat
  • Basic skills in thermodynamic calculations
  • Research the principles of calorimetry and effective mass calculations
  • Study the thermodynamic properties of water and CO2
  • Explore methods to minimize heat loss in calorimetry experiments
  • Investigate the impact of experimental conditions on phase change measurements
Students and researchers in chemistry and physics, particularly those involved in calorimetry experiments, thermodynamics, and phase change analysis.
Dumile
I have decided to do away with the template; all calculations have been done, I'm just having trouble interpreting the results.
An experiment was performed using a calorimeter and warm water. The data collected gave the following values for heat of fusion for ice, and heat of sublimation of dry ice:
a) 17.06g of ice melted in 30.9°C water with mass 77.29g
Final water temp = 13.3°C.
ΔT = T(final) - T(initial) = 30.9 - 13.3 = -17.6°C
total energy absorbed(lost by water):
Q=4.18j/g°C x 77.29g x -17.6°C = 5686J.
Heat of fusion calculated:
L = Q/m = 5686J/17.06g = 333.3J/g <-- this is close to accepted value of 334J/g. So far so good.
b) 11.85g of ice melted in 13.3°C water with mass 94.35g.
Final water temp = 4.5°C. ΔT = -8.8°C
Total energy absorbed(lost by water) = 3471J.
Heat of fusion calculated = 292.9J/g <-- this is much lower than the accepted value. Why is this? Other than experimental error, is there a reason for this? I thought heat of fusion was constant between 0°C and boiling point.
c) 8.5g of dry ice (solid CO2) melted in 30.8°C water with mass 82.35g
final water temp = 15°C. ΔT = -15.8°C
Total energy absorbed(lost by water) = 5439J.
Heat of sublimation calculated = 663.3J/g. <-- accepted value is 571J/g. Why is the value higher? Is it because the evaporation process undergone by the dry ice cools the water to a greater degree, thus driving up the value of absorbed energy, which increases the value for latent heat?
I would like to understand what is happening here. Any insight would be great.
ps. Apologies if this thread is hard to follow - I'm new to all of this.
Your analysis is based on the assumption that no heat escapes to the environment. Realistically, this is not so. How did you take into account the sure fact that heat also needs to be removed from the walls before the contents reach equilibrium? Most calorimetry experiments that I am familiar with involve determination of the "effective mass" of the calorimeter before one starts one's measurements.
10K
