How Can the Midpoint Rule Estimate the Volume of a Liver from CAT Scan Data?
  • Thread starter Thread starter tictactony
    Volume
The discussion focuses on estimating the volume of a liver using the Midpoint Rule based on CAT scan data with cross-sectional areas provided at intervals of 1.5 cm. The liver's length is 15 cm, and the areas are given as 0, 19, 58, 79, 95, 105, 116, 128, 63, 40, and 0 square centimeters. The Midpoint Rule with n = 5 is applied, but confusion arises due to the requirement of selecting 6 data points from 11 available, leading to the suggestion of using n = 10 instead. The relationship between surface area and volume is clarified, emphasizing the dimensional analysis of the readings and intervals.
  • Understanding of the Midpoint Rule in numerical integration
  • Familiarity with CAT scan imaging and cross-sectional data analysis
  • Knowledge of Riemann sums and their application in volume estimation
  • Basic principles of dimensional analysis in calculus
  • Study the application of the Midpoint Rule in numerical integration techniques
  • Learn about the disk method for volume calculation in calculus
  • Explore dimensional analysis and its importance in mathematical modeling
  • Investigate the implications of data selection in numerical methods
Students studying calculus, particularly those focusing on numerical integration methods, as well as professionals in medical imaging and data analysis who require a solid understanding of volume estimation techniques from cross-sectional data.
tictactony
A CAT scan produces equally spaced cross-sectional views of a human organ that provide information about the organ otherwise obtained only by surgery. Suppose that a CAT scan of a human liver shows cross-sections spaced 1.5 cm apart. The liver is 15 cm long and the cross-sectional areas, in square centimeters, are 0, 19, 58, 79, 95, 105, 116, 128, 63, 40, and 0. Use the Midpoint Rule with n = 5 to estimate the volume V of the liver.
Not sure what I'm suppose to use, disk method? [tex]V = \int\pi r^{2}[/tex]
I'm not sure if I'm supposed to treat this like I would a normal riemann sum using the midpoint rule because the question is asking for a volume and I'm given surface area. The way I see this problem I feel like I have to add up all the surface areas because that's what you do when you find volume by integration. This wouldn't make sense though since I'm given the midpoint rule of n=5.
That is puzzling given that the data cover 10 intervals. It smells like a question that has been modified inconsistently.
n=5 requires 5 intervals, so 6 datapoints. Which 6 of the 11 to choose? I would answer using n=10.
You have a set of readings at boundaries of given intervals. If the readings have dimension X and the intervals have dimension Y then the sum of the pairwise products has dimension XY. In this case, X=L2, Y=L, so XY=L3.
15K
  • · Replies 18 ·
