Finding potential of two points in a constant electric field
The problem involves calculating the electric potential at two points in a constant electric field, with specific coordinates and a known potential at one point. The context includes the relationship between electric field strength and potential difference, as well as the implications for work done when moving a charge within the field.
  • The original poster attempts to calculate the potential at point 2 using the distance between the two points and the electric field strength, but expresses confusion over the results. They question whether the electric field value changes and how to approach the work calculation for moving a charge.
Participants are exploring the implications of the constant electric field on potential differences and discussing the work done in moving a charge. Some guidance has been offered regarding the relationship between distance and potential, but there is no explicit consensus on the calculations or assumptions being made.
The problem includes constraints such as the constant nature of the electric field and the specific coordinates of the points in question. The original poster also raises questions about the interpretation of the electric field's constancy and its effect on potential calculations.
skibum143
The figure below shows two points in an E-field: Point 1: (3,4) and Point 2: (12,9) both in m. The electric field is constant, with a magnitude of 80 V/m, and is directed parallel to the +X axis. The potential at point 1 is 1100 V. What is the potential at point 2?
E = change in V / change in X
A^2 + B^2 = C^2
I got that the distance (tangent) between points 1 and 2 is 10.296 m. If I plug that into the equation to solve for V, I get 80=(V2 - 1100) / 10.296, or V2 = 823.68. Since Point 2 is further away from the origin of the E-field, the potential should be lower, so 1100 - 823.68 = 276.32. This is wrong. I tried adding them to see if that was right, (1923.68) but that was wrong too.
My main question is does the E-field value change? It says it is constant, so I don't know why it would. Thanks for the help!
The second part of the question is to calculate the work required to move a negative charge of Q = -608 microC from point 1 to point 2, which I would use the formula: the change in PE = the change in V times the charge (q). Is this right?
Welcome to PF!
Hi skibum143! Welcome to PF! :smile:
(try using the X2 tag just above the Reply box :wink:)
Potential = potential energy per charge …
potential energy = work done …
what is the work done if you go a distance 9 parallel to the x-axis?
what is the work done if you go a distance 5 parallel to the y-axis? :wink:
Hi tiny-tim. Thanks so much for the response!
The work going a distance 5 parallel to the y-axis is zero, because it's on the same equipotential line.
So should I only be using 9 as my "r" instead of the tangent of 10.296?
sorry, i meant use 9 as my change in x...
I guess my other main question is, if they say the electric field is constant, at 80 V/m, is that the value at every point in the electric field? If not, how do you calculate the change in the electric field?
AH! I got it! Thank you so much! :)
:biggrin: Woohoo! :biggrin:
But, slow down in future! :smile:
you don't usually get a quick response here, so you may as well take your time! :wink:
  • · Replies 16 ·
