Potential and Kinetic Energy with Time Thrown In
The problem involves a stone thrown vertically upwards, requiring the calculation of kinetic and potential energy at specific time intervals. The subject area includes concepts of energy, motion, and the effects of gravity.
  • The original poster attempts to calculate kinetic and potential energy but expresses uncertainty about incorporating time and height. Some participants suggest using kinematic equations to find height at given times, while others question the implications of negative kinetic energy values.
Participants are exploring different approaches to the problem, with some providing equations and calculations. There is an ongoing discussion about the interpretation of results, particularly regarding the conditions at 2 seconds and the use of different values for mass and time.
There is a noted lack of clarity regarding the height values needed for potential energy calculations, and participants are questioning the assumptions made about energy at different time intervals.
kriegera
A stone weighing 0.2 kilograms is thrown vertically upwards with a velocity of 19.6 meters per second. Neglecting the friction of the air, calculate the kinetic and potential energy it possesses at the end of 1 second and 2 seconds respectively.
I found total kinetic energy here:
Total Kinetic Energy=1/2 times mass times velocity squared
KE = (1/2)(0.2)(19.2) ^2 = 36.864
- just not sure how to find it after "1 and 2 seconds respectively."
I know potential energy =
Egrav=mgh
but i don't have a height value so even rearranging doesn't work:
And rearranging to solve for h=Egrav/mg = ?
How do you solve for kinetic and potential energy when you have the added component of time and missing components of height?
Use h = ut-1/2gt^2 where u is the initial velocity of the body.
u is given. t is known. Find h at the end of 1 s and 2 s. Then find PE = mgh.
Then KEf = KEi - mgh.
This is what i got:
For 1 second h=(19.6)(1)-1/2(9.8)(1) ^2 = 14.7
For 2 seconds h = (19.6)(2) – ½(9.8)(2) ^2 =19.6
PE=mgh
For 1second = PE=(0.2)(9.8)(14.7) = 28.812
For 2seconds = PE (0.2)(9.8)(19.6) = 38.416
For Kinetic Energy-1second
KEf = 36.864 – (0.2)(9.8)(14.7) = 8.052
For Kinetic Energy – 2seconds
Kef = 36.864 – (0.2)(9.8)(19.6) = -1.552
Is this correct? Can that last kinetic energy value be negative?
In the second case
final velocity after 2 second is
v = u - gt = 19.6 - 2*9.8 = 0.
So at 2 second KE = 0.
Ok -thanks. Why does the equation change for the second time-for 2 seconds? Why would you use PE-tgh in the first one and H-gt in the second? Is it b/c at 2 seconds, PE would be 0?
one more quick thing - why did we use 0.2 for seconds in the first equation but 2.0 in the second?
0.2 kg is mass, and 2 second is the time.
  • · Replies 21 ·
