Finite Element Analysis Program
The discussion revolves around the simulation of heat capacitance and thermal conductance of materials for a research project related to heated flooring. Participants explore the feasibility of using finite element analysis (FEA) programs to model these properties under specific conditions.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks a program to simulate a looping heating pipe at a set temperature to analyze the conductance of a material.
  • Another participant emphasizes the necessity of knowing material properties beforehand to conduct analyses, suggesting that manufacturers typically provide these parameters.
  • A different viewpoint proposes that if temperatures and geometry are known, it might be possible to back-calculate the desired material properties.
  • One participant suggests that iterating on material properties may be required to match boundary conditions in the simulation.
  • Another comment highlights the complexity of not knowing thermal conductivity (k) or heat capacity (C), indicating that this leads to the need for iteration in both space and time.
Participants express differing views on the necessity of known material properties for simulations, with some suggesting back-calculation is possible while others emphasize the importance of having these properties defined beforehand. The discussion remains unresolved regarding the best approach to take.
There are limitations regarding the assumptions made about the availability of material properties and the specific conditions under which simulations can be accurately performed. The discussion does not resolve the mathematical steps involved in back-calculating material properties.
DapDunkerley
I am on a research project where I am finding the heat capacitance and thermal conductance of a material and would like to simulate it on a larger scale as material for heated flooring. Is there a program where I can do a looping heating pipe at a set temperature and show the conductance of the material?
You need to know the material properties in order to run most analyses. Unless you knew the resultant heat transfer or some other result, you can't back calculate the material properties. Most materials already have these parameters defined by the manufacturer. Can't you simply get in touch with whomever makes the materials you are interested in and get the data that way?
Material properties are fundamentally an input. If you know the temperatures and geometry, can you back-calculate the material properties you desire?
I would think you would have to iterate on the material properties until you match your current boundary conditions.
...and not knowing k or C means iterating both in space and time. Yay!
  • · Replies 21 ·
  • · Replies 0 ·
