Thread Closed
carnot process question
Share Thread
Jan28-10, 02:20 PM   #1
Four identical blocks of copper, of mass 20Kg each, are 'perfectly' isolated from the environment. One is kept at a temperature of 573K and the other three at 288K. The heat capacity of copper is 375 J/K/Kg. Assume a carnot process is being used to exploit the temperature differences between the se 4 blocks of copper. How much work can maximally be extracted?
(Hint: the temperature of the copper blocks change continuously from initial to final temperature. Remember that a carnot process is reversible, the total entropy change is zero)
2. Relevant equations
1. [tex]T_{f}=T_{1}^{\frac{m_{1}}{m_{1}+m_{2}}}*T_{2}^{\frac{m_{2}}{m_{1}+m_{2} }}[/tex]
3. The attempt at a solution
"Treating it as 1 block of 573K at 20Kg and 1 block of 288K at 60Kg and using T1 = 573, T2 = 288 and m1 = 20, m2 = 60 i get;
[tex]T_{mix}=359.25K[/tex]
[tex]T_{f}=573^{\frac{20}{80}}*288^{\frac{60}{80}}[/tex]
[tex]T_{f}=342.04K[/tex]
now using [tex]\Delta{E}=mc\Delta{T}[/tex]
[tex]\Delta{E}=80*375*(359.25-342.04)=516300J[/tex]
[tex]\Delta{S}=\frac{\Delta{E}}{T}-\frac{\Delta{W}}{T}[/tex]
As theres no entropy change the delta S terms is zero which leaves,
[tex]\frac{\Delta{E}}{T}=\frac{\Delta{W}}{T}[/tex]
the T's cancel and your left with extractable work = 516300J"
Does this seem correct? im not sure about the 'Tmix' part and the last part where delta E is converted to delta W.
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Jan28-10, 11:04 PM   #2
Recognitions:
Homework Helper Homework Help
I am having difficulty following your reasoning. I think you have to apply the equation for efficiency to determine the work as a function of temperature. Initially, the extractable work is:
[tex]dW = \eta dQ_h = (1-\frac{T_c}{T_h}) cmdT [/tex]
Write out the relationship between Tc and Th and do the integration.
AM
Thread Closed
Tags
carnot, carnot process, entropy, heat engine
Similar discussions for: carnot process question
Thread Forum Replies
adiabatic process in carnot cycle Advanced Physics Homework 4
Carnot Cycle question Introductory Physics Homework 1
Carnot cycle question Classical Physics 0
Carnot Cycle and Adiabatic process Introductory Physics Homework 15
Carnot Engine - Carnot Refrigerator Introductory Physics Homework 2
