Finding E field inside a sphere with charge proportional to radius
The discussion focuses on calculating the electric field inside a sphere with a charge density proportional to the radius, expressed as ρ = kr. By applying Gauss' law, the surface integral for a sphere of radius R is derived, leading to the formula E(R) = kR²/(4ε₀). The user successfully solved the problem by integrating the charge density over the volume of the sphere and utilizing spherical coordinates for the calculations.
  • Understanding of Gauss' law in electrostatics
  • Familiarity with spherical coordinates in calculus
  • Knowledge of electric field concepts and charge density
  • Basic proficiency in LaTeX for mathematical expressions
  • Study the derivation of Gauss' law and its applications in electrostatics
  • Learn about charge distributions and their impact on electric fields
  • Explore spherical coordinates and their use in triple integrals
  • Practice writing mathematical expressions in LaTeX for clarity in presentations
Students in physics, particularly those studying electromagnetism, as well as educators and anyone interested in understanding electric fields generated by non-uniform charge distributions.
Vapor88
First time poster here! EDIT: SOLVED!
Thanks, I figured out from the related links at the bottom of the page. >_>b
Find the electric field inside a sphere which carries a charge density proportional
to the distance from the origin, [tex]\rho[/tex] = kr, for some constant k.
[tex]\oint E.da[/tex]
[tex]a = 4 \pi r^2/3[/tex]
[tex]da = 4 \pi r^2[/tex]
[tex]\rho = kr[/tex]
[tex]E = q/(r^2 4 \pi \epsilon _0)[/tex]
Where q = charge inside
[tex]\oint E \bullet da = \int q/(r^2 4 \pi \epsilon _0) \bullet 4 \pi r^2[/tex]
The 4 pi r^2 terms cancel, leaving on the right
[tex]q/ \epsilon_0[/tex]
Substitute rho into the eqn. as to integrate all dimensions of the sphere
[tex]\int \rho d \tau / \epsilon_0[/tex]
Here's where I get stuck, I know that
What do I do with [tex]d \tau[/tex]? I'd imagine that it'd be easiest to do in spherical coordinates, so do I just add dr, dtheta, drho?
Also... How do I put a dot into this LaTex thing?
Thank you!
You do not know the electric field, but you can calculate it by applying Gauss' law.
Because of symmetry, E depends only on r and is the same along a sphere of radius R. The surface integral for a sphere of radius R is equal to Q/epszilon, where Q is the charge confined inside the sphere
[tex]4 \pi R^2 E(R) = \frac{4 \pi}{\epsilon}\int_0^R{kr*r^2dr=\frac{4\pi}{\epsilon}k R^4/4 \rightarrow E(R)=\frac{kR^2}{4\epsilon}[/tex]
ehild
  • · Replies 17 ·
  • · Replies 43 ·
