You have a cup, it has a mass of 1 Kg.
  • Context: Undergrad
  • Thread starter Thread starter STAii
    Mass
The discussion centers on calculating the density of a liquid in a cup with a mass of 1 Kg, containing a liquid with a mass of 1.5 Kg. A known volume object is submerged in the liquid, with scale X reading 7.5*g N and scale Y reading 2.5*g N. The correct approach concludes that the real weight of the object is 7.5*g N, leading to the density of the liquid being calculated as d = 5/V, where V is the volume of the object submerged.
  • Understanding of Newton's laws of motion
  • Knowledge of buoyancy principles
  • Familiarity with free body diagrams
  • Basic grasp of density calculations
  • Study the principles of buoyancy and Archimedes' principle
  • Learn how to draw and interpret free body diagrams
  • Explore density calculation methods in fluid mechanics
  • Investigate the relationship between weight, mass, and gravitational force
Physics students, educators, and anyone interested in fluid mechanics and buoyancy calculations will benefit from this discussion.
STAii
In the cup is a liquid, with a mass of 1.5 Kg.
the Cup (and liquid) are on a weight scale (call it X).
We have another object, with known volume (call it V), attached to a spring-scale from upwards (call it Y).
The object was put inside the liquid (not floating), X reads 7.5*g N, Y reads 2.5*g N, what is the density of the liquid.
Now, what most people i know did is that they said :
The weight of cup and liquid = (1+1.5)*g = 2.5*g N
And since scale X reads 7.5*g N, then the real (not apparent) weight of the object must be 5*g N (and they start to solve from there).
What i have made is that i drew a free body diagram, and i reached the conclusion that the real weight of the object is 7.5*g N.
Who do u think is right ?
Thanks in advance.
Not quite: the "Y" scale is supporting SOME of the weight.
The total weight of all parts: cup, fluid and object is the sum of the readings of X and Y: (7.5+ 2.5)g N= 10g N. Since we know that the cup and fluid together weigh 2.5g N it follows that weight of the object is, as you say, 10gN- 2.5gN= 7.5g Newtons.
The difference between that and the 2.5g N reading of the Y scale (i.e. 5.0g N) is the bouyancy of the fluid. It is equal to the volume of fluid displaced (and since it is not floating, that is the volume of the object) times the density of the fluid. You have the equation dV= 5 so that d, the density of the fluid is given by 5/V
Just as i expected.
Thanks !
  • · Replies 128 ·
12K
  • · Replies 202 ·
15K
  • · Replies 131 ·
9K
  • · Replies 17 ·
  • · Replies 23 ·
  • · Replies 51 ·
12K
