How can a sequence of simple conformal transformations map one line to another?
  • Thread starter Thread starter sara_87
    Transformation
The discussion revolves around using a sequence of simple conformal transformations to map a line defined by two points, {(-1,0),(0,i)}, to another line represented by {z=2+i*s, s is real}. Participants explore the implications of these transformations and the nature of the mappings involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the initial attempts to map the original points to the target line and question the validity of their mappings. There is exploration of how conformal transformations can be applied to achieve the desired mapping, including considerations of rotation and translation.
There is an ongoing exploration of different transformation methods, with some participants providing hints and suggestions for approaching the problem. Multiple interpretations of the transformations and their effects are being considered, and participants are encouraged to verify their results through testing.
Participants note that the solution may not be unique and discuss the implications of different transformations, including rotations and translations, on the mapping of the original points. There is also mention of the need to check the transformations against the original points to ensure correctness.
sara_87
Use a sequence of simple conformal transformations to find the function f(z) mapping the line
going trough the points {(-1,0),(0,i)} to the line given by the set {z=2+i*s, s is real}.
let z=(-1,0) so when we put this into z=2+i*s, we get that s=3*i, when z=(0,i), we get s=1+2i.
does this mean that it maps to the line joining the points (0,3i) and (1,2i)?
I think this is wrong...
any ideas?
thank you.
Yes this is wrong. You have tried to find your two original points, using the formula for the vertical line that you are supposed to en up with. But this is imposible, since the two points are not not the line {z=2+i*s, s is real}.
You have to find conformal transformations that will "move" your two original points onto the vertical line given by {z=2+i*s, s is real}.
So you need to check how each of the simple conformal transformations affect your two orignal points, and then try to find which conformal transformations that will actually move your points onto the vertical line.
Torquil
Said differently:
The original line is given by
{ (-1,0) + r(1,i), r is real}
If z -> f(z) is a conformal transformation, then this will be transformed into
{ f((-1,0) + r(1,i)), r is real}
You need to find such a conformal transformation f, such that this set is the same as
{2+i*s, s is real}
So you need to check which types of f you are allowed to use, i.e. which f that represent conformal transformations. And when you know this, determine which of them that solves the problem.
Good luck!
Torquil
Oh right, the problem is much clearer now, thanks.
But, does this mean the line y=i(x+1) gets mapped onto y=2+is
How do i know where the original points get mapped onto on the new line?
But, does this mean the line y=i(x+1) gets mapped onto y=2+is?
Yes, but isn't it "y=i(x+1) gets mapped onto x=2"? You probably meant to say "z=2+is" and to think of s as a the parameter that defines the line when it takes different real values. In terms of only the x and y-variables (real and imag parts of z), you want to transform your original line y=i(x+1) into the line x=2.
I don't know :-) Actually I think they can end up in many different places, because I think the solution is not unique.
Torquil
I see why it's the vertical line x=2.
so the conformal transformations should be a rotation that makes the line y=i(x+1) vertical then a simple shift to the right.
right?
but now i have to figure out the equations of these tranformaitions
Yes, that would be correct.
for the rotation part, would it be:
f(z) = ze^(-i*(pi/4))
Since you have a minus in the exponent, wouldn't this result in a horizontal line? I would think that the sign should be positive to get a vertical line?
Oh right.
clockwise direction means negative so anticlockwise is positive...right?
so would the final transformaiton be w=ze^(i*pi/4) + 3
Yes that is probably right. Allthough you should test your result by applying it to those two points, and see if the x-value of both results is equal to 2.
Torquil
from the point (0,i)
w = i(e^(i*pi/4))+3 = sqrt(2)/2 i + (3-sqrt(2)/2)
so that means
w=ze^(i*pi/4) + 3
is wrong
I think your +3 is incorrect. After having rotated the line to become vertical, it no longer intersects the x-axis at (-1,0). It will intersect at some other point. Therefore you need to find this point first, and after than you will know which you should use instead of +3.
Torquil
i can imagine it...the point will be closer to the origin.
but how can i find this point?
I can give you a hint for a simpler solution: First, translate so that your 45 degree line goes through the origin. Then rotate 45 degees. Then translate one more time to the right.
Torquil
to translate it to go through the origin, do i do: w=z+1 ? because this also wouldn't work
I would say that the result should be
Translate to intersect with the origin: z -> z+1
Rotate 45 degrees: z -> z*e^(i*pi/4)
Translate it to x=2: z -> z+2
I think the composite transformation therefore is
z -> (z+1)*e^(i*pi/4) + 2
But I may be wrong of course, so you should check it using both of the points (-1,0) and (0,i). If it is wrong, then you could check each individual step of the transformation. E.g. check that you have a vertical line through the origin after step 2, and so on.
Torquil
yes, this works.
sorry, i forgot to change the +3 to +2.
you said that f(z) is not unique, how can i verify this?
sara_87 said:
yes, this works.
You can see this because you could have just as well rotated 180+45 degrees. Also it doesn't matter if you add any translation along the line in the beginning, or along the vertical line in the end. So e.g. it doesn't matter if you add anything proportional to i in the end result.
Also, you could have also used any conformal scale transformation when your line was intersecting the origin. That would not have changed anything either, because a straight line through the origin is invariant under a scaling about the origin.
EDIT: So from these examples, you see that the two original points that defined the original 45 degree line can end up anywhere in the line x=2. The scaling I mentioned would change the distance between them, a translation along the line will move them anywhere, and a 180 degree rotation will be able to change their order.
Torquil
