Toyota Recall: Is Your Vehicle Affected?
  • Thread starter Thread starter Ivan Seeking
    Vehicle
The discussion revolves around the recent Toyota recall affecting various models due to concerns about accelerator pedal issues. Participants share personal experiences, speculate on the causes of the problems, and discuss the implications of the recall on Toyota's reputation and production.
  • Some participants recount personal experiences with Toyota vehicles, noting past issues with floor mats affecting pedal operation.
  • There is mention of a newer Corolla that has not experienced problems, alongside advice regarding handling potential accelerator issues.
  • Concerns are raised about the material used in the accelerator linkage arm, which some believe is a significant factor in the recall affecting 1.5 million cars.
  • A participant expresses confusion about the recall's scope, particularly regarding why certain models like the 2006 Prius are not included in the current recall despite being on a previous list.
  • Some participants speculate about the transition to a drive-by-wire system and its potential role in the issues being reported.
  • There are discussions about the manufacturing locations of the suspect parts, with references to both U.S. and Canadian facilities.
  • One participant expresses confidence in Toyota's ability to resolve the issues, contrasting it with other manufacturers' responses to recalls.
  • Concerns are voiced about the perception that Toyota may have delayed issuing the recall despite knowledge of the problems.
  • Participants note that recalls are common across many vehicle brands, emphasizing the challenges of mass production.
  • There is a distinction made between the floor mat issue and potential electronic problems, suggesting multiple factors may be at play.
Participants express a mix of confidence in Toyota's handling of the situation and skepticism regarding the company's prior knowledge of the issues. There is no consensus on the root causes of the problems, with multiple competing views on the significance of the accelerator assembly and the floor mat issues.
Some participants highlight the complexity of automotive manufacturing and the potential for multiple issues to arise simultaneously, indicating that the discussion may be limited by incomplete information about the recall's specifics.
Ivan Seeking
Staff Emeritus
Has anyone here been affected by this?
http://www.toyota.com/recall/?srchid=K610_p228906387
Funny thing, we are long-time Toyota devotees and had this problem with a 1994 Corolla. The pedal was too close to the floor. The floor mat could either slide up and press the pedal, or it could hold a depressed pedal in place. Being that it was a stick-shift, I made a point to keep the floor mat away from the pedal and never gave it a second thought.
We have two later model Toyotas but are unaffected by the recall.
My brother and his wife have a newer Corolla and they haven't had any problems yet. In case you didn't know the word from Toyota is if it happens to you make sure not to remove the keys (you will lose power steering) and don't hold the break down pump it.
My cousin's daughter had problems with a used Corolla, but they stemmed from replacement floor mats. The clutch-pedal interlock made it hard to start the car, and the mat could trap the accelerator pedal. Her father and I trimmed the drivers' side mat back to alleviate both, and no more problems. That was a nice little car and it served her well all through college. Toyota's current troubles seem a bit more systematic. Too bad, because the Camry always seemed to be up on top of the heap for quality, along with the Accord. We have severe winters here, so my wife and I have standardized on Subaru - if we lived in a warm climate, Honda or Toyota would have gotten a lot more attention.
The current problem they said has to do with the material on the accelerator linkage arm. Something so simple overlooked is causing 1.5 million cars to be recalled. Crazy.
I'm a bit confused about the latest recall. It looked like a followup of the previous floor mat recall. My 2006 Prius was on the original floor mat recall list but is not on the current accelerator recall list that contains most of the same cars. I could guess at a number of reasons but, it would be nice to know why some cars were dropped. The fact that they aren't on the second list says that the Prius only accelerates out of control due to floor mats. I really don't believe that floor mats were ever the real problem - although Turbo-1's comments make me wonder about my opinion.
Toyota has actually shut down production on the new models listed. They can't even sell the ones already on a dealership's lot. It couldn't have happened at a worse time.
I don't know exactly what year that they switched to a drive by wire accelerator, but it has to be a part of the problem. There have been several crashes of vehicles that had the floor mats removed.
Consumer Reports video.
I have absolutely no concerns about this in the long run. Tsu and I have driven Toyotas over a million miles with very few repairs beyond normal maintenance; in fact I am hard-pressed to think of anything done beyond normal maintenance. We did lose one engine at about 180,000 miles, but that was my fault. Toyota has my complete confidence. They will fix the problem and move on.
My only complaint on the older Toyotas was the valve timing belt - a belt failure can take out the engine. However, we had this replaced every 50K miles [less one that went 100K by mistake] and never had a problem.
We lost the engine due to maintenance issues. Back when I was on the road a lot [flying, not driving], I was working a ridculous number of hours each week and was gone much of the time. As a result, we inadvertantly neglected maintenance for long periods of time. Dirty oil finally did us in.
Most of the vehicles affected no longer have an accelerator linkage they use a drive by wire system. The accelerator assembly that sends the signal to the CPU is suspect.
They are starting to install a brake/accelerator override in new vehicles.
http://www.autoweek.com/article/20100112/CARNEWS/100119974
The suspect accelerator assembly is made in the USA:frown:
Canada?
rootX said:
Canada?
Canada is a definite possibility. Indiana based CTS Corp has a plant there.
http://news.yahoo.com/nphotos/Toyota-Motor-Corp/ss/events/bs/010307toyotamotor/im:/100127/480/0bb16b78ee984514863a9b83cb51ff96
Ivan Seeking said:
I have absolutely no concerns about this in the long run...Toyota has my complete confidence. They will fix the problem and move on.
That seems to be the opinion of a lot of people,
Rather than deny the problem and try and suing news outlets (like a certain car maker) they have gone beyond what's was required and are likely to get a lot of brownie points from current/future buyers. Even the component supplier is saying nice things about how they will learn from this in the future - rather than everyone concentrating on liability/blame.
ps. I just got a recall for my 3year old Subaru - but nothing serious
There is bound to be a recall of something on every mass-produced vehicle brand out there eventually. I think the big deal about this isn't that there is a recall, but that people seem to think Toyota has known about the problem for a while and not issued a recall sooner.
Even my Subaru currently has a recall on it, but I haven't had time to get it fixed, and it doesn't sound like anything major as long as I don't try taking a lot of sharp corners with a nearly empty tank of gas (it's a fuel flow regulator of some sort that is faulty...the part that made me laugh is that when you get it fixed, the fix is just to remove it as they have decide the part isn't needed...so they put in a part that's useless and only causes trouble...ha ha). Before the Subaru, I had Fords, and there were recalls on those too. One was something I noticed before the recall came out and felt completely vindicated when I finally could show the moron mechanics that I WASN'T being "too sensitive" as they kept telling me when I was explaining something didn't "feel" right about how the car was running (it was a hard one to explain and their lugfeet couldn't feel it). The other was something really silly on a door latch or something...I just had that done when it was in for some other routine maintenance...it was a back door issue and I usually drove alone, so didn't even care.
With all the parts that go into cars and with the high volume of production, all it takes is one bad batch of something that goes undetected to affect a lot of cars. Since I personally can't afford a custom-designed car, I'll continue to take my chances with the occasional recall of the mass-produced ones.
Toyota has specifically denied that.
It seems that cars made for the US markets used plastic for a critical part of the linkage, whereas cars not sold in the US use a metal part that has had no problems. So this may get back to the US supplier that you listed, CTS.
Also, the floor mat problem is a separate issue. There have actually been two separate problems [assuming that the electronics are not also a problem].
I agree, if the recall fixes all the problems with the gas pedal, and there is still a more remote computer (ECU) to throttle body assembly issue with some cars that survivors of crashes claim to have caused the problem, and Toyota doesn't come clean on it, then their reputation will be damaged to a large degree or ruined forever.
Two survivors on the major news swear that the pedal was not depressed and the computer opened the butterfly valve and provided max fuel. I have no reason not to believe them. There was a famous case in San Diego a few years back where a family of four were killed because they couldn't stop their Toyota Sequoia, even after calling 911, tape played in the news clip, chilling. The major problem is that this has been happening intermittently for years, not months or days and Toyota has not stepped up to the plate.
As a side Note: Mercedes back in early 2000 timeframe experimented with a fly-by-wire braking system, no direct control hydraulically to the brakes, but through a computer and after much thought, trial, etc... decided to not put it in their cars, a very wise choice IMHO.
They admit they "feel the need" to put "Bleeding edge" technology (pun intended) in their cars to keep a competitive advantage.
Rhody...
Yeah, I saw it years ago. In my opinion it wasn't bad as far as science fiction movies go.
Honestly, if you don't know that you shift the car into neutral and not turn the car off if it the throttle gets stuck, you should be reduced to riding a bicycle. There is no excuse for driver ignorance on the road.
If your toyota begins to accelerate, try and crash it. You have a better chance at getting cash money from toyota than winning the lottery.
Knowing to do it while sitting there comfortably behind the keyboard of your computer and having that reaction the first time you ever experience an out-of-control situation like that while driving down a busy highway are two completely different things. This isn't like being an aircraft pilot who goes through hours and hours and hours of flight simulator training to practice reacting to unexpected emergency situations. Most people who experience something that strange in a car have no way to be prepared to actually react to it.
Think back to the first time you were driving a car that stalled. Did you immediately know what to do, or did you momentarily panic and then figure it out? And a stall is more the problem for the person driving behind you than for you. It usually has to happen a couple times before it becomes an immediate reaction to throw the car in neutral to restart.
Of course they are two different things, but it should be common knowledge if you are going to be driving a car.
They should be prepared for it. If you aren't prepared for the unexpected you don't belong on the road.
Would I have panicked if I was not warned of a stalling problem? Of course, but only for a second because it does not take a rocket scientist to figure out a solution instantaneously.
But did I panic? No, I was told that the truck would stall when it came to a complete stop, so I knew what to expect, all I did was push the clutch in and start it up again. Wasn't a huge deal because I knew that if it were to happen, I had the necessary tools to fix the problem. (in this case pushing the clutch in and starting it). Now that the toyota drivers know what could happen, and know how to remedy the situation, there should be absolutely no excuse for failure to execute.
This unfortunately happened to a family. They had time to call the cops, but not enough common sense to shift a car into neutral to disengage the transmission. It is sad that they died, but some common sense goes a long way.
If I had my way, our drivers education program would be exactly like the Fins. I believe it is 2 years of class with countless hours behind the wheel defensive driving. They just so happen to have the most successful WRC drivers.
Things that happen only very rarely can be tough to deal with in a crunch situation. I had a cop come up behind me very fast with lights and siren on, while biking on a fairly curvy road. I had no time to scrub speed so I pulled my Wide Glide over to the breakdown lane, at full speed, with brakes applied lightly. When my rear wheel crossed the paint, it locked up. Quick! What do you do? The most natural response can kill you in a heartbeat.
turbo-1 said:
when my rear wheel crossed the paint, it locked up. Quick! What do you do?
jump!
Pray
You let the rear wheel skid, feather the front brakes, and look where you WANT to go, not where you fear to go. Even on a Wide Glide with a skinny front tire, the front brakes provide most of your braking power. As you try to slow, you unload the rear tire, and unlocking a skidding rear wheel at speed can easily throw you out of control and kill you.
A lot of people think that they would know what to do in and instant. And probably a lot of people do know what to do. It would be no problem for me.
On the other hand how many people even use the neutral position on a vehicle anymore except to zip right past it on the way to Drive. I don't think that the average driver could even find neutral without taking a close look at the PRNDL indicator.
I can see where the vehicles with the 3.5 liter engine and a six speed automatic could get confused.
BTW Steve Wozniac of Apple claims that he has an acceleration problem with his Prius when using his cruise control to accelerate.
http://abcnews.go.com/Blotter/Runaw...a-told-us-gas-pedals-problem/story?id=9730328
DO NOT PUMP THE BRAKE:
I have to concur. Sharon Stone's part was one of her best roles.
That was Toyotal Recall, geez! you guys are slipping.
LOL I hadn't noticed jimmysnyders post. I thought you guys had lost it.
Did no one think to turn the key off?
You could also shift into reverse, destroying the transmission. If the engine wants to red line it won't matter, because its now cut off from the drive shaft.
When I was in star bucks yesterday I read the cover of the washington post. They had an article about an off duty cop with his family that had this happen in their Lexus. He called 9-1-1 and said the pedal was stuck and he had no brakes (he was on the highway, so he was already going fast). Apparently they crashed into someone/something and all died. Not cool.
Turning the key off turns off power steering and greatly reduces breaking power which will result in a crash.
11K
9K
10K
