| Thread Closed |
Differentiation of a trig function using quotient rule |
Share Thread | Thread Tools |
| Feb1-10, 06:13 AM | #1 |
Find the derivative of [tex]\frac{sin x}{1 + cos x}[/tex] 2. Relevant equations Quotient rule [tex]\frac{gf' - fg'}{g^{2}}[/tex] 3. The attempt at a solution [tex]\frac{dy}{dx}[/tex] = [tex]\frac{(1 + cos x)(\frac{d}{dx}(sin x)) - sin x(\frac{d}{dx}(1 + cos x)}{(1 + cos x)^{2}}[/tex] simplify the derivative so far: = [tex]\frac{(1 + cos x)(cos x) - (sin x)(-sin x)}{(1 + cos x)^{2}}[/tex] simplify further: = [tex]\frac{cos x + cos^{2}x + sin^{2}x}{(1 + cos x)^{2}}[/tex] Use angle identity [tex]sin^{2}x[/tex] + [tex]cos^{2}x = 1[/tex]to simplify even further: = [tex]\frac{cos x + 1}{(1 + cos)^{2}}[/tex] cancel out the common 1 + cos x [tex]\frac{dy}{dx}[/tex] = [tex]\frac{1}{1 + cos x}[/tex] I was quite confident in my answer, but I was a little teeny bit hesitant, so I used my graphing calculator to double check. When I did so, I found out that I was wrong, the derivative that I calculated (above) is not the actual derivative of the question. At which step did I go wrong? Thanks so much in advance everyone! |
| Feb1-10, 06:40 AM | #2 |
Recognitions:
Hm, I don't see where the mistake is. If there is one at all. Perhaps you messed up your input in the graphics calculator?
| Feb1-10, 06:42 AM | #3 |
Hi stripes!
![]() Looks ok to me. ![]() As a double-check, using standard trigonometric identities … sinx/(1 + cosx) = tan(x/2), so dy/dx = 1/2 sec2(x/2) = 1/(1 + cosx). What answer did your calculator give? |
| Feb1-10, 06:52 AM | #4 |
basically, on my graphing calculator i put y1 as my original function, then y2 as the derivative that I found. I then used the calculator to find dy/dx of y1 for me at various points (maybe 1, 2, and 3), then I used the calculator to find the values of x = 1, 2, and 3 for y2 and the respective values should be the same...but they weren't!
I'm almost certain i was error free inputting the functions...I did it over and over and over! |
| Feb1-10, 09:18 AM | #5 |
Mentor
| Thread Closed |
| Thread Tools | |
Similar Threads for: Differentiation of a trig function using quotient rule
| Differentiation - Quotient rule | Calculus & Beyond Homework | 3 | ||
| Differentiation quotient rule question, am i wrong or is my book wrong? | Calculus & Beyond Homework | 1 | ||
| Derivative of a trig function/chain rule | Calculus & Beyond Homework | 5 | ||
| Differentiation (Trig Function) | Calculus & Beyond Homework | 4 | ||
| Problem with Differentiation Using Quotient Rule | Calculus & Beyond Homework | 1 | ||
