Gravitational Energy and Kepler's Law
The discussion revolves around a double-star system where two stars of equal mass rotate about their center of mass. The original poster seeks to determine the common angular speed of the stars and the minimum speed required for a meteoroid to escape the gravitational influence of the system.
  • Mixed
  • The original poster attempts to apply Newton's second law and gravitational force equations to find the angular speed and escape velocity. Some participants suggest equating centripetal force with gravitational force to derive the necessary velocities. Others question the need for separate equations for each star and discuss the implications of gravitational force in relation to the radius.
The discussion is ongoing, with participants providing guidance on the application of relevant equations. There is a recognition of the original poster's attempts, but some confusion remains regarding the calculations and assumptions made. Multiple interpretations of the problem setup are being explored.
The original poster has indicated a deadline for the homework, which may be influencing the urgency of the discussion. There is also a mention of a potential misunderstanding regarding the gravitational force's dependence on the distance between the stars.
jetsfan101202
1. In a double-star system, two stars of mass 6.0 *10^30 kg each rotate about the system's center of mass at a radius of 2.0 * 10^11 m.
(a) What is their common angular speed?
(b) If a meteoroid passes through the system's center of mass perpendicular to their orbital plane, what minimum speed must it have at the center of mass if it is to escape to "infinity" from the two-star system?
F=-GMm/r^2
A=V^2/R
V(orbit)=sqrt(GM/r)
U(gravitational potential energy) = -GMm/R
I tried to do F=ma and a=v^2/r so m(v^2/r)=GMm/r^2
any help would be greatly appreciated. I need this done by midnight. thanks so much
Welcome to PF!
In all circular orbit problems, begin with the fact that the centripetal force is the gravitational force: Fc = Fg
Put in the two detailed formulas for the forces (with the mass and radius in them). Then you can solve for the velocity or period easily. And one more step to get the angular velocity.
isn't that what I did in my attempt at a solution? the only other thing I realize is that the force of gravity is 2r not r. so m(v^2/r)=GMm/(2r^2). Do I need two separate equations for both stars?
Sorry, jetsfan - I failed to see that you already had done what I suggested!
Now I don't understand why you are stalled.
You have v² = GM/(4r) so v = 2.24 x 10^4 m/s.
From there you can get ω = v/r in a moment . . . and you're done.
Oh, is it the wrong answer?
  • · Replies 30 ·
  • · Replies 39 ·
