Could a Machine Magnetize Cast Iron Parts More Than Steel?
  • Context: Undergrad
  • Thread starter Thread starter sophiecentaur
    Iron Steel
The discussion centers on the potential for a machine, traditionally used for machining steel parts, to inadvertently magnetize cast iron components. Participants explore the conditions under which magnetization may occur, particularly focusing on the influence of temperature and the presence of DC currents in the machine.
  • Some participants suggest that the machine may cause low-level magnetization of cast iron parts, despite its previous use with steel without apparent magnetization.
  • It is noted that stainless steel does not magnetize depending on nickel content, which may be relevant to the comparison being made.
  • Participants mention that machining cast iron at temperatures around 770°C could lead to magnetization, although there is uncertainty about whether the machine reaches such temperatures.
  • Questions are raised about the source of DC currents in the machine, with some speculating they originate from the drive motors.
  • One participant emphasizes the importance of safety regarding the DC currents and suggests verifying if cast iron gets magnetized after addressing the DC issue.
  • It is highlighted that cast iron, containing 2.1-4% carbon, is more easily magnetized compared to other materials.
Participants express uncertainty regarding the temperature reached during machining and the implications of DC currents, indicating that multiple competing views remain on the topic.
There are limitations regarding the assumptions about temperature and the specific machining processes involved, as well as the nature of the DC currents and their effects on magnetization.
sophiecentaur
Does it seem reasonable that a machine which has, up until now, been used for machining steel parts without, apparently, leaving them magnetised could be causing low level magnetisation of the same parts when made of cast iron? There are some DC currents flowing in the machine, apparently but suspect that they've not been high enough to magnetise the steel bits.
Could be.
Stainless steel does not magnetize (depending on Ni content).
If the process of machining cast iron happens around 770'C magnetization can occur.
Why are there DC currents flowing through the machine?
Lok said:
Could be.
I don't think it gets this hot in this machine but I'll enquire.
This isn't stainless steel that I'm comparing it with.
The DC, I think, is in the drive motors. This is a huge machine making car engine parts but I only know of the problem second hand.
Machining is a very hot process at least where the metal is cut, that is why they use cooling liquid. What type of machining does it do?
Fix the DC (safety first) and then see if it Cast Iron gets magnetized. Cast Iron has 2.1-4% in carbon, so it is easily magnetized.
  • · Replies 43 ·
  • · Replies 21 ·
