How Does the Jones Polynomial Relate to Different Knot Configurations?
  • Context: Graduate
  • Thread starter Thread starter marcus
    Polynomial
The discussion focuses on the relationship between the Jones polynomial and various knot configurations, specifically the trefoil knot. The skein relation is highlighted, demonstrating how the Jones polynomial for different knot types can be derived. The key results include the Jones polynomial for two unlinked unknots as J(two separate unknots) = - t1/2 - t-1/2 and for the right-hand trefoil knot as Jones(righthand trefoil) = - t4 + t3 + t. The connection between knot theory and Quantum Field Theory, as established by Witten, is also noted as a significant aspect of the Jones polynomial's relevance.
  • Understanding of knot theory concepts, including unknots and linked/unlinked loops
  • Familiarity with the Jones polynomial and its axioms
  • Knowledge of the skein relation in knot theory
  • Basic grasp of Quantum Field Theory and its relation to topology
  • Study the derivation of the Jones polynomial for various knot types
  • Explore the implications of the skein relation in knot theory
  • Investigate the historical context of Witten's work on the Jones polynomial and Quantum Field Theory
  • Learn about the classification of knots, particularly the differences between left-hand and right-hand trefoils
Mathematicians, physicists, and students interested in knot theory, topological invariants, and their applications in Quantum Field Theory will benefit from this discussion.
marcus
Dearly Missed
I don't see immediately how I can talk about knot theory
here at PF because I can't easily draw pictures. this is a test.
I'll try to discuss the (Vaughn) Jones polynomial by first
drawing 3 simple PARTS of knots and naming them and
then trying to get some results. Like about the trefoil.
this is following the AMS knot website as best I can with limited graphics.
Here are downover and upover and nocross
Code:
The skein relation talks about three knots that look exactly the same except at one location, where one has downover, one has upover, and one has nocross.
the Jones of the three knots are related as follows
t-1 Jones(downover) - t Jones(upover) = (t1/2 - t-1/2) Jones(nocross)
If you do a change of variable and substitute 1/t for t you will see that the roles of downover and upover can be exchanged.
THE JONES AXIOM :wink:----- Jones(unknot) = 1
An unknot is just a circle or some equivalent simple loop. Twist an unknot and lay one lobe inside the other. Then it looks like two concentric circles except for a crossing. Call that unknot'
Twist it the other way and again lay one lobe inside the other. Again two concentric circles except for (the other kind of) crossing. Call that unknot''. By the mighty Jones axiom we have that:
J(unknot') = J(unknot'') = 1
Notice that if in either of these two you were to replace the solitary crossing by a "nocross" then you would get two concentric circles or anyway two concentric unknots.
BUT BY THE VERITABLE SKEIN RELATION we have that:
t-1 J(unknot') - t J(unknot'') = (t1/2 - t-1/2) J(two concentric unknots)
Now we apply the AXIOM and on the LHS have simply t-1 - t
We are going to SOLVE for J(two concentric unknots)
t-1 - t = (t1/2 - t-1/2)J(two concentric unknots)
But (t-1 - t )/(t-1/2 - t1/2) = (t-1/2 + t1/2)
So, not losing track of the minus sign, we have
J(two concentric unknots) = - t1/2 - t-1/2
This fact about the Jonesj polynomial evaluated on two unknots (they don't have to be concentric, simply unlinked) is a useful fact.
We can use it to find out what Jones of a trefoil knot is.
Mathematics news on Phys.org
So we just got this result that the Jones polynomial of any two unlinked loops----its a topological thing, they don't have to be concentric----is
How about two LINKED loops? The skein relation works here too:
By drawing a picture you can see that changing one crossing from upover to downover or vice versa will separate the two---unlink them. Also replacing that crossing by a nocross will just produce one long unknot.
t-1 Jones(two linked unknots) - t Jones(two unlinked unknots) = (t1/2 - t-1/2) Jones(unknot)
Substitute 1 for J(unknot) and substitute
- t1/2 - t-1/2
for J(two unlinked loops) and we have:
t-1 Jones(two linked unknots) - t (- t1/2 - t-1/2) = (t1/2 - t-1/2)
t-1 Jones(two linked unknots) + t3/2 + t1/2 = t1/2 - t-1/2
Jones(two linked unknots) + t5/2 + t3/2 = t3/2 - t1/2
Jones(two linked unknots) = - t5/2 - t1/2
A chain with just two links has that polynomial.
The Jones polynomial is a topological invariant and key to a lot of knot theory. Witten was awarded the Fields medal for discovering a relation between the Jones polynomial and Quantum Field Theory. My understanding is he won it for his work in QFT, of which the connection to knots is maybe the most far-reaching. Relating QFT to knots happened in 1989 or so, I think.
We should be able to get the invariant of the trefoil next.
J(any unknot) = 1
J(two linked unknots) = - t5/2 - t1/2
The way a trefoil knot is usually drawn it has 3 lobes and 3 crossings.
If you pick one crossing and replace it by the other kind of crossing you get an unknot (draw a picture to see)
And if you replace the crossing by a nocross you get two linked loops----linked unknots!
So one application of the skein relation should do it:
t-1 Jones(trefoil) - t Jones(one long unknot) = (t1/2 - t-1/2) Jones(two linked unknots)
Jones(trefoil) - t2 Jones(one long unknot) = (t3/2 - t1/2) Jones(two linked unknots)
Then applying the "axiom" to the one long unknot and what we found out already about two links:
Jones(trefoil) - t2 = (t3/2 - t1/2) (- t5/2 - t1/2)
Jones(trefoil) - t2 = - t4 + t3 + t - t2
Jones(trefoil) = - t4 + t3 + t
I should go to the AMS site and check this. Am wondering if there are two inequivalent kinds of trefoil and maybe this is just the polynomial for one of them.
Yeah, I looked. What I did was the RIGHTHAND trefoil, and it is correct. Jones studied oriented knots where there is an arrow along the rope. If you grasp the rope with your right hand, thumb in the direction of the arrow, then in the righthand trefoil all the crossings are with your curl of your fingers.
Graduate Knots In 4D
  • · Replies 32 ·
  • · Replies 20 ·
  • · Replies 0 ·
