Thread Closed
Calculating Speed of Falling Banana - "Just Before" it Hits Ground?
Share Thread Thread Tools
Feb5-10, 02:05 PM   #1
"A monkey drops a banana. Its weight is 1N. It falls 3 metres to the ground. What is the speed of the falling banana just before it hits the ground?"
2. Relevant equations
Not sure, but I'm guessing I need to calculate the kinetic energy the banana gains (which was 3J) and the change in GPE (which was also 3J).
3. The attempt at a solution
My textbook says the answer is 7.8 m/s, but I have no idea why. As I've said above, I've worked out the change in GPE and kinetic energy the banana gains, but why is the answer 7.8 m/s and how are you supposed to arrive at this solution?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb5-10, 02:12 PM   #2
before the banana hits the ground the velocity is max, which means that the kinetic energy is max so total energy at the moment is kinetic energy .. and at the point just before the monkey drops the banana the potential energy is max with value = mgh=1*3=3J so your total energy is 3J , thus the max. kinetic energy is 3J and you know that the kinetic energy = 0.5*m*v^2 (here m =0.1 kg) then substituting you will find that v =7.74 m/s
Feb5-10, 02:30 PM   #3
thebigstar25 is correct, this is all about Conservation of Energy. Potential Energy at the start is equal to the Kinetic Energy at the bottom. And since you know the Force and Acceleration, you can figure out Mass. (F=ma) Then just plug it into the equation for PE (PE=mgh).
Thread Closed
Thread Tools
Similar Threads for: Calculating Speed of Falling Banana - "Just Before" it Hits Ground?
Thread Forum Replies
which drop of water has more "force" to hit ground? Introductory Physics Homework 2
Was this a good investment: The "banana bill" at $25K? General Discussion 22
"Kerry Hits Nail on Head" Current Events 1
Insect Evidence in Mysterious Banana Squash "Symbols" General Discussion 0
If disaster hits NY "hide under desk" General Discussion 2
