Compute area using divergence and flux?
  • Context: Graduate
  • Thread starter Thread starter nebbie
    Area Divergence Flux
The discussion focuses on computing the area enclosed by the curve defined by the parametric equations g(t) = a cos³(t), a sin³(t) for t in the interval [0, 2π]. The user has successfully derived the unit tangent and outward normal vectors but seeks guidance on calculating the area without a specified vector field F. The solution involves applying Green's Theorem, which relates the line integral around a simple closed curve to a double integral over the plane region bounded by the curve. By selecting M(x,y) = x and L(x,y) = 0, the area can be computed effectively.
  • Understanding of parametric equations and curves
  • Familiarity with Green's Theorem in vector calculus
  • Knowledge of divergence and flux concepts
  • Ability to compute line integrals and double integrals
  • Study the application of Green's Theorem in various contexts
  • Learn about divergence and its role in vector calculus
  • Explore examples of computing areas using parametric curves
  • Investigate the relationship between flux and area in vector fields
Mathematicians, physics students, and anyone interested in vector calculus, particularly those looking to deepen their understanding of area computation using Green's Theorem and parametric curves.
nebbie
Compute area using divergence and flux??
Consider the curve given by g(t) =acos^3(t),asin^3(t), where t is [0; 2pi] and a > 0 is a constant.
(a) Find the unit tangent and outward normal vectors.
(b) Compute the area enclosed by this curve.
I have done part a), and I know that
flux of F = divergence x area
but for part b), i m not given a vector field F. so how am I suppose to approach this question and possibly find the divergence (thus the area)? any hint or solution would be much appreciated. ^__^
Since this is in the plane, it is simpler to use Green's theorem rather than the divergence theorem.
Green's theorem says that
[tex]\oint (Ldx+ Mdy)= \int\int \left(\frac{\partial M}{\partial x}- \frac{\partial L}{\partial y}\right) dA[/tex]
The integral on the right will be the area as long as
[tex]\frac{\partial M}{\partial x}- \frac{\partial L}{\partial y}= 1[/tex]
One such choice is M(x,y)= x, L(x,y)= 0.
  • · Replies 24 ·
15K
