How does a changing electric flux produce a magnetic field?
  • Thread starter Thread starter fluidistic
    Field
The discussion revolves around a capacitor with circular plates and the relationship between changing electric flux and the resulting magnetic field. Participants are exploring the implications of applying a sinusoidal voltage across the capacitor and how this affects the electric and magnetic fields in the vicinity.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of Maxwell's equations and the assumption of a uniform electric field between the plates. There are questions about the appropriate value for the electric field and the calculation of electric flux. Some participants express confusion about the relevance of elliptic integrals and the implications of fringing effects at the edges of the capacitor.
Guidance has been offered regarding the use of Gauss's law and the relationship between voltage, electric field, and electric flux. Some participants are exploring the implications of their calculations and questioning their understanding of the magnetic field's behavior in relation to the changing electric flux.
Participants are navigating the complexities of the problem, including the assumptions about uniformity of the electric field and the nature of the magnetic field outside the capacitor. There is an acknowledgment of the potential for confusion regarding the application of various equations and concepts.
fluidistic
There's a capacitor with circular plates of radius 50 mm and separated by a distance of 5 mm. We apply a sinusoidal difference of potential whose maximum value is 150 V and has a frequency of 60 Hz. Determine the amplitude of the magnetic field, between the plates and at a distance of 50 mm away from the center of the capacitor.
I've no idea.
I've no clue about what equation to use. I'm thinking about Maxwell's equation: [tex]\oint \vec B d\vec s =\mu _0 \varepsilon _0 \frac{d\Phi _E}{dt}+\mu _0 I_{\text{enclosed}}[/tex] but I'm not even sure.
In any case, I'm almost sure I have to calculate the E field of such a capacitor. I don't know if this is right, but I reached that the E field in a point situated inside the capacitor and over the straight line passing by both center of the plates as to be worth [tex]4\pi d \sigma \int _0 ^{0.005} \frac{dr}{r^2 \sqrt{r^2+d^2}}[/tex] and I'm stuck here.
But I'm not sure this is relevant to calculate the E field only in this line.
I've also figured out that [tex]V(t)=150 \sin (60 t)[/tex] and that [tex]\vec E =-\nabla V[/tex].
Any tip is greatly appreciated as I'm at a loss.
I think you are making this problem more complicated than it is. Assume that the electric field is uniform between the plates (even though your point of interest is at the edge where fringing is significant). Then you can easily relate V to E to the electric flux and use Maxwell's equation as you suggested.
If you do not wish to assume that the electric field is uniform between the plates, then to calculate it off the axis, where your point of interest lies, you need to do an elliptic integral and I don't think you want to go there.
Thanks for the tip kuruman. I'm still somehow confused. Say I assume the E field is uniform between the plates, what value do I choose? As I know it's not uniform, I don't know what value (average maybe?) of the E field to take.
And about the elliptic integral, you're right, I would not go there! But next semester starts the serious (Jackson's book) E&M course, so don't be surprised if I pop up with such an integral.
I think you're still overcomplicating it. V=Ed since E is uniform, so E=V/d. Now you can find an expression for electric flux and apply Ampere's law.
Thanks. I don't know if I'm on the right way, I get that the net flux through the plates is worth [tex]\frac{V_0 \sin (\omega t)}{d} \cdot 2 \pi r^2[/tex] by applying Gauss's law. Is this right? If so, I'm goint to tackle the rest.
This is the net electric flux through what area?
Gauss' law? :confused: You just multiply electric field by area to get flux. E=V/d and A=pi*r^2, so flux is just V/d*pi*r^2.
Through the two plates... oh... I should divide by 2, right? Because flux enters one plate and leave the other. So I'm wrong.
So it would be [tex]\frac{V_0 \sin (\omega t)}{d} \cdot \pi r^2[/tex]. Am I right?
Edit: Ok I got it! I plan on to continue!
Now I guess that [tex]I_{\text{enclosed}}=0[/tex] because I don't see any circuit, but I'm not 100% sure. If I assume that, I reach [tex]\oint \vec B d \vec s=\frac{\mu _0 \varepsilon _0 V_0 \sin (\omega t)}{d}[/tex].
I'm not able to figure out in my head the magnetic field. Where is it? What is its direction?
For the sake of guessing, I guess I'll simply end up with [tex]Bd=\frac{\mu _0 \varepsilon _0 V_0 \sin (\omega t)}{d}[/tex], thus [tex]B=\mu _0 \varepsilon _0 V_0 \sin (\omega t)[/tex].
That would be between the plates of the capacitor.
And for any points outside it, does B=0 since E (hence the E flux)=0?
Yes, Ienclosed = 0. It is the displacement current that produces the magnetic field. To see the relation of the magnetic field to the changing electric flux, look at the equation
[tex] \oint \vec B d\vec s =\mu _0 \varepsilon _0 \frac{\partial}{\partial t}\int \vec{E}\cdot\hat{n}dA[/tex]
The line integral is over the contour loop that forms the boundary of the area through which you are calculating the electric flux. The loop is oriented so the circulation in the sense of integration matches the normal to the surface with the use of the right hand rule.
  • · Replies 31 ·
  • · Replies 16 ·
  • · Replies 25 ·
  • · Replies 26 ·
