How are we able to differentiate both sides of an equation?
  • Context: Undergrad
  • Thread starter Thread starter Juwane
    Differentiate
The discussion revolves around the differentiation of both sides of an equation, specifically examining the equation x^3 = x + 6. Participants explore the implications of differentiating when the equality holds only for specific values of x, and the conditions under which differentiation is valid.
  • One participant notes that differentiating both sides of the equation leads to an incorrect result, questioning the validity of this operation when x changes.
  • Another participant argues that the two functions represented by the equation are not tangent but merely intersect at specific points.
  • Several participants emphasize that equality of functions must hold for all x to differentiate both sides, suggesting that pointwise equality does not imply equality of derivatives.
  • One participant provides a geometric perspective, stating that if two functions intersect but are not equal, their derivatives cannot be the same at the intersection point.
  • Another participant illustrates that differentiating constants results in trivial equations, reinforcing that differentiation requires knowledge of function behavior over intervals.
  • A participant clarifies that the initial assumption of equality between the functions is a misstep, suggesting that the focus should be on specific values where the functions are equal rather than treating them as equal functions.
Participants express disagreement regarding the conditions under which differentiation is valid. There is no consensus on whether it is appropriate to differentiate both sides of the equation when equality holds only for specific values of x.
Participants highlight limitations in understanding the nature of equality between functions and the implications of differentiating constants versus functions. The discussion remains focused on the nuances of mathematical operations rather than reaching a definitive conclusion.
Juwane
Consider this equation.
[tex]x^3 = x + 6[/tex]
If we solve for x we'll get x=2
Now if we differentiate both sides with respect to x, we get
[tex]3x^2 = 1[/tex]
If we now put x=2, we get
[tex]3(2)^2 = 12 = 1[/tex]
Which is of course wrong. So how can we differentiate both sides of an equation when the value of x changes after the differentiation?
The two functions aren't tangent to each other. They just intersect.
Why do you think
f(a) = g(a)​
should imply
f'(a) = g'(a)​
If these functions were actually equal -- i.e. f = g or equivalently f(x)=g(x) for all x -- then the derivatives would be equal functions too -- i.e. f' = g' or equivalently f'(x) = g'(x) -- and thus f'(a) would be equal to g'(a).
From a more geometric perspective, arithmetic operations act pointwise -- e.g. (f+g)(a) = f(a) + g(a) -- but derivatives require knowledge of the neighborhood of a point -- knowing f(a) doesn't tell you anything about f'(a).
The analogous statement for derivatives is that if f(c)=g(c) for all c in the interval [itex](a-\delta, a + \delta)[/itex], then f'(a) = g'(a).
One third comment. If the premise of a problem is that x is a number such that x3=x+6, then differentiation with respect to x is nonsense.
So you mean that if f(x)=g(x) for all x, only then we can differentiate both sides?
I think if you were to sketch both [tex]x^3[/tex] and [tex]x + 6[/tex] and their derivatives then all your questions would be answered.
Yes, if "F" is any kind of operation that gives a unique answer and a= b, then F(a)= F(b). That's what "unique" means!
Since the derivative is an operation of functions, if f(x)= g(x) are equal functions, then f'(x)= g'(x) for all x and, in particular, f'(a)= g'(a).
Since the derivative is NOT an operation on individual numbers, the fact that f(a)= g(a) are equal numbers does NOT mean that f'(a)= g'(a)
Because equality of functions is pointwise: If "f(x)=g(x) for all x" holds, then "f=g" holds.
And if "f=g" holds, we can substitute: "f'" is equal to "g'".
Then we can apply the fact equality is pointwise again to get: "f'(x)=g'(x)".
Since differentiation is local, we also have that "f(x)=g(x) for all x in (a,b)" implies "f'(x)=g'(x) for all x in (a,b)".
Of course, good answers are already given. For an "extreme" example:
x = 1-x
differentiate
1=-1
If we substitute x=1/2, a solution of the first equation, we still have 1=-1, a contradiction :)
If you draw the graphs of x and 1-x, you will see that they are in fact perpendicular to each other in the intersection x=1/2! (which was already obvious from the 1 and -1 obtainend from differentiating.) So no way their derivatives are the same in that point: they would have to be parallel, but they are in fact the opposite, perpendicular.
x = 1-x
differentiate
1=-1
The point being that the original equation, x= 1- x, is only true for x= 1/2. It is NOT an equality of functions. It does NOT say that f(x)= x and g(x)= 1- x are equal for all x.
I'm not quite sure why you want to repeat that. I was just providing extra geometric explanation.
Here's another way to think about it. If you have an equation like f(a)=g(a) for some particular value a, then you are absolutely justified in differentiating both sides. But you won't get f'(a)=g'(a). Instead you will get 0=0, because both f(a) and g(a) are constants. (This follows from the fact that a is a constant).
By the way, this reminds me of a riddle that a teacher once posed to me in high school: Since multiplication is repeated addition, if x is some particular natural number then x^2=x+x+x+x+...x (x times). If we differentiate both sides we get
2x=1+1+1+1+...1 (x times) = x, and therefore 1=2.
The resolution is the same: since both sides are constants, when we differentiate the equation we get 0=0.
Think carefully about what it means to be doing what you're doing.
From the very start, you have two functions. Let's give them names for clarity:
f(x) = x^3
g(x) = x + 6
Note that f and g are not the same function. They are not equal.
What's the first line you put down?
Boom. You say just the opposite. That they ARE equal. That's the first misstep.
What you really meant to say wasn't that the functions are equal. In fact, it wasn't even a statement. It was more like a question. "For what values of x are f(x) and g(x) equal?" In set notation, you'd write this as {x | f(x) = g(x)}.
What you're interested in is the few values of x where f(x) = g(x) [in this case, there's only one: x = 2]. So we're working with the assumption that whatever value x is, f(x) = g(x). We can then investigate the values of x.
Now here's a subtle part that's leading you stray. You can take the derivative of both sides only if both sides are functions. This is not the case.
But f(x) is a function, right? Wrong. The function is called "f". When we write "f(x)", that's "the evaluation of f at x". They are two different things! If you have f = g, then, by all means, f' = g'. In fact, if f = g, then f'(x) = g'(x), because you're again doing the same thing to both sides of an equation (evaluating both sides at x).
When you say f(x) = g(x), you're talking about two numbers being equal, not two functions. And you can't take the derivative of a number. If we are working with a problem that says "f(x) = g(x) for all x", then we can conclude f = g. But this is not the case here! In this problem, we are told f(x) = g(x) for a handful of values. That's totally legit, but you can't conclude f = g and therefore you can't conclude that f' = g' nor f'(x) = g'(x).
Hope that helps a bit :)
  • · Replies 16 ·
  • · Replies 17 ·
