Free Body Diagram for Hanging Weight with Two Ropes | Tension Comparison
The discussion revolves around analyzing a free-body diagram for a system involving a hanging weight supported by two ropes connected to a steel cable. Participants are tasked with determining the tensions in the ropes based on the forces acting at the knot where the ropes connect.
  • Participants explore the relationships between the lengths and tensions of the ropes, questioning whether the length of one vector affects its tension. There is also a discussion about the components of the forces in both horizontal and vertical directions, with some participants suggesting that only the vertical components need to be considered.
The discussion is ongoing, with participants providing insights into the balance of forces and the relationships between the tensions in the ropes. Some guidance has been offered regarding the need to consider vector components, but no consensus has been reached on the correct approach to the problem.
Participants are working under the assumption that the knot is not accelerating, which implies that all forces must balance. There is also a constraint regarding the maximum tension that the ropes can sustain without breaking, which is set at 4000 N.
mybrohshi5
Two ropes are connected to a steel cable that supports a hanging weight as shown in the figure.
http://session.masteringphysics.com/problemAsset/1000050931/2/YF-05-59.jpg
Draw a free-body diagram showing all of the forces acting at the knot that connects the two ropes to the steel cable.
Based on your force diagram, which of the two ropes will have the greater tension?
n/a
So Vector length: C<A<B
or should the length of C equal the length of A+B?
So vector A will have the greater tension than vector B because it is shorter?
Does this look and sound correct?
thank you :)
Also could i get a little help with the last part of this question:
If the maximum tension either rope can sustain without breaking is 4000 N, determine the maximum value of the hanging weight that these ropes can safely support. You can ignore the weight of the ropes and the steel cable.
so i found the weight each rope can hold.
4000sin(60)= 3464
4000sin(4)= 2571
then i added these two together to get 6035 N but this is incorrect?
does anyone know where i went wrong?
thank you
Since the knot isn't accelerating, all forces acting on it have to balance each other.
To break this problem down, what you want to do is consider the components of each vector in the horizontal (x) and vertical (y) directions. Once you do this, you can determine the magnitudes of A and B in terms of C.
For the second part of the question, you first consider which rope will have the most tension on it and that's the one that would be first to break. Then, with a tension of slightly less than 4000 N, go back to the relative magnitudes of each vector you determined in the first part.
so since its just hanging wouldn't i only need to deal with the y components of the vectors A and B?
so if this is true then the y component of A and the y component of B would have equal the length of the vector C?
  • · Replies 38 ·
  • · Replies 25 ·
