Need help answering problems related to Buoyance/Buoyance Force
  • Thread starter Thread starter Sam
    Force
The discussion revolves around two homework problems related to buoyancy and buoyant force, specifically focusing on the forces acting on a submerged man and a helium balloon in air. The subject area includes principles of fluid mechanics and Archimedes' principle.
  • The original poster attempts to calculate the buoyant force acting on a submerged man and a helium balloon, referencing Archimedes' principle and specific gravity. Some participants question the calculations and suggest potential adjustments to the approach.
Participants are actively engaging with the problems, with one providing a detailed attempt at solving the first problem. There is a suggestion to reconsider the sign in the final expression for the force required to keep the man submerged. No consensus has been reached on the correctness of the calculations yet.
The original poster mentions that the course provides feedback on correctness, indicating that the answers may be subject to validation through the course platform.
Sam
I have two homework problems that I am unable to answer related to buoyancy/force. Please help! Thanks!
1. How much force (in Newtons) does it take to hold a 100kg man completely under water in the ocean? His density is 903 kg/m^3, and the specific gravity of sea water is 1.07.
They give the following hint: Buoyant force is greater than the weight: B.F. = Weight + Force Down
2. What is the buoyant force in N on a 6.6 m^3 helium balloon in air at standard conditions? The density of air is 1.3 kg/m^3
They give the following hint: According to Archimedes you only need to know the weight of the air displaced.
Sam,
what have you got so far and where are you stuck? If you haven't started yet, then I think Archimedes' law is a good starting point.
Here's what I have so far...
I have the following, but I know my answer isn't correct because it's an online course and will let you know when you are correct:
Let:
Mm = mass of man in kg (given at 100 kg)
Vm = volume displaced by man in m^3 = Mm/Dm
Sg = specific gravity of seawater (given at 1.07)
Dw = Density of pure water 1 gm/cm^3 = 1000kg/m^3
Ds = Density of seawater
Fb = Buoyancy force
g = acceleration of gravity in m/s^2 = (9.8 m/s^2)
Here's how I tried to solve:
Fb = Vm*Dw*g
= (Mm/Dm)*Sg*Dw*g
= (100 kg/903kg/m^3)*1.07*(1000kg/m^3)*9.8m/s^2 N
Ok, so the buoyant force exceeds his weight. To keep him submerged you'd have to push him down with the difference force F=1161 - 980 or about 181 N.
What did I do wrong?
Hmmm... looks OK to me. With the following changes, which don't change the result:
Fb = Vm*Sg*Dw*g
= (Mm/Dm)*Sg*Dw*g
= (100 kg/903kg/m^3)*1.07*(1000kg/m^3)*9.8m/s^2 no N
Since they say B.F. = Weight + Force Down, maybe they expect the answer to have a minus sign. Suggest you try that.
