Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Materials & Chemical Engineering
Notices
Reply
image Fatigue Failure on Turbine Blade(large subsonic aircraft) Share It Thread Tools Search this Thread image
Old Feb8-10, 09:40 AM                  #1
billcc
billcc is Offline:
I am doing a project on the subject above, and i am selecting one type of material that is currently popular used in gas turbine, but i found it difficult to select the material as there are too many nickel-based alloy that can be use for this application. Can anyone direct me with a suggestion on what type of materials should i choose and any specific link that can provide the properties of the material?
Besides that, i am looking for development of turbine blade material used since 1940s until now, but i can't seems to find any relevant info on it. Can anyone share some info regarding this?
by the way, from my readings, i found that nowadays, mostly turbine blade are produce to be single crystal plus enhancement of properties with coatings. Is this true for the application of aircraft engine turbine blade available nowadays?
Old Feb8-10, 10:23 AM                  #2
Astronuc
PF Mentor
Astronuc's Avatar
Astronuc is Offline:
Re: Fatigue Failure on Turbine Blade(large subsonic aircraft)
See this thread - http://www.physicsforums.com/showthread.php?t=242166
Directional solidification and single crystal are preferred methods for turbine blade manufacture.
Ceramic coatings extend the lifetime.
Old Feb8-10, 01:10 PM                  #3
billcc
billcc is Offline:
Dear Astronuc,
regarding this thread, this link below seems to be unavailable:
http://www.eprictcenter.com/infocent...aper02_msw.pdf
this link seems to have statistic that i wanted, are there any similar link that i can make use?
by the way, does CMSX-4 belong to the preferred materials used for turbine blade nowadays?
are there any link that relate the performance of turbine blade with the fatigue failure mechanism? such as, corrosion-fatigue, creep-fatigue, thermal-fatigue, etc.
thanks for showing me such a useful thread.
Old Feb8-10, 01:49 PM       Last edited by Astronuc; Feb8-10 at 02:04 PM..            #4
Astronuc
PF Mentor
Astronuc's Avatar
It could be the site is down, or they've changed the url, or they no longer have the paper available.
The paper may no longer be available. One could contact the authors:
Materials Technology for Advanced Land Based Gas Turbines
R. Viswanathan, Ph.D., EPRI, Palo Alto, CA 94304, USA
S. T. Scheirer, Ph.D., Power Tech Associates, Media, PA 19063, USA
Meanwhile try this -
http://www.netl.doe.gov/technologies...book/4.4.1.pdf
http://www.osti.gov/bridge/servlets/...able/72949.pdf
http://www.gepower.com/prod_serv/pro...s/ger3569g.pdf
CMSX-4 is one of the preferred materials.
image image
Reply
Tags
turbine blade
Thread Tools
Similar Threads for: Fatigue Failure on Turbine Blade(large subsonic aircraft)
Thread Thread Starter Forum Replies Last Post
Advanced Heat Transfer - Conduction Cooling in Turbine Blade MechanicalMan Engineering, Comp Sci, & Technology 4 Sep29-09 05:18 PM
wind turbine blade design ads. Aerospace Engineering 1 Oct28-08 07:21 AM
wind turbine blade characteristics CPP Aerospace Engineering 5 Oct23-08 06:54 AM
preliminary stress and vibration analysis of turbine blade everybody Mechanical Engineering 2 Oct8-08 12:31 PM
FLUENT - Turbine Blade Cooling this_dude Mechanical Engineering 2 May26-08 11:57 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2010 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
