<- Albrecht said ->
"..There is exactly one preferred inertial frame (i.e. absolutely at rest)"
COMMENT: Before you comment on the rest of the feedback I provide in this message,
PLEASE show us an article that experimentally shows that there is a preferred inertial frame in the universe. This is critical to your reputation because the statement is indeed very controversial.
<- Albrecht said ->
"...several examples for problems with the Einsteinian interpretation of special relativity. There are more of it. E.g. the twin paradox"
There are two errors you have made in the above statement ALONE. The first is only a matter of terminology, but the second is a poor analysis of the problem.
1/ There is no other interpretation of "special relativity". The term "special relativity" was coined by Einstein and is nothing more than the Lorentz transformations (which are a result of his two postulates). As many other people will concede, Einstein's two postulates (alone) are used to derive the Lorentz transformations. The derivations are entirely algebraic and are done in a first- or second-year physics course.
2/ The "twin paradox" is not a paradox for special relativity, and as such is not a "problem" for it (as you say it is). Here is a link to a proper (accepted) analysis:
http://www.phys.unsw.edu.au/~jw/twin.html
Please don't continue posting incorrect information; it will confuse (and mislead) those who are not properly informed.
I have decided to include some references to very recent articles with other experiments (there are quite a few of them) which demonstrate superluminal pulse propagation.
They ALL demonstrate superluminal* propagation while maintaining causality and are 2003 publications.
If you would like to challenge the authors, it is only fair to e-mail them (and their institution) with your objection.
* "superluminal" according to the currently accepted definition
Search the website http://prola.aps.org/search to see where I obtained these references:
V. Petrillo, et al., Phys. Rev. A 67, 012110 (2003)
...Some of the characteristic times of tunneling are calculated and compared; they are all of the same order of magnitude and all indicate an apparent superluminal motion, even if causality is maintained...
S. L. Konsek, et al., Phys. Rev. B 67, 045306 (2003)
...Tunneling transport is shown to be causal, and no evidence of superluminal behavior is seen, either for resonant or for off-resonant tunneling...
H. G. Winfil, et al., Phys. Rev. Lett. 90, 023901 (2003)
...The theory presented here provides a physical explanation of the tunneling process and resolves the mystery of apparent superluminality...
D. Rohrlich, et al., Phys. Rev. A 66, 042102 (2002)
...We discuss the consistency of weak values and show that superluminal weak speed is consistent with relativistic causality...
D. Solli, et al., Phys. Rev. E 66, 056601 (2002)
...The causality principle does not forbid negative group delays of analytic signals in electronic circuits; in particular, the peak of a pulse can leave the exit port of a circuit before it enters the input port...
...Furthermore, pulse distortion for these "superluminal" analytic signals can be negligible in both the optical and electronic domains...
Regarding the twin paradox:
The Hafele and Keating Experiment
(a proof of time dilation)
Ref: J.C. Hafele and R. E. Keating, Science 177, 166 (1972)
Quote from Science article:
"During October, 1971, four cesium atomic beam clocks were flown on regularly scheduled commercial jet flights around the world twice, once eastward and once westward, to test Einstein's theory of relativity with macroscopic clocks. From the actual flight paths of each trip, the theory predicted that the flyng clocks, compared with reference clocks at the U.S. Naval Observatory, should have lost 40+/-23 nanoseconds during the eastward trip and should have gained 275+/-21 nanoseconds during the westward trip ... Relative to the atomic time scale of the U.S. Naval Observatory, the flying clocks lost 59+/-10 nanoseconds during the eastward trip and gained 273+/-7 nanosecond during the westward trip, where the errors are the corresponding standard deviations. These results provide an unambiguous empirical resolution of the famous clock "paradox" with macroscopic clocks"
