How Does Distance Affect Light Intensity According to the Inverse Square Law?
The discussion revolves around the application of the inverse square law of light intensity in relation to distance from a light source. The original poster presents a scenario where the intensity of light at a distance of 1 meter is given, and they seek to calculate the intensity at greater distances.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between distance and light intensity, referencing the inverse square law. Some express confusion about applying the formula and seek clarification on how to substitute values into the equations.
Participants are actively discussing the application of the inverse square law, with some providing guidance on how to set up the calculations. There is a recognition of the mathematical relationship, but a lack of consensus on the specific steps to take for each distance calculation.
The original poster indicates a lack of understanding and expresses frustration with the instructional approach of their teacher. There is also mention of rounding answers appropriately, suggesting attention to detail in the calculations.
Nul
A source of light is used to illuminate a screen. 1 m from the source, the intensity of the light falling on the screen is 12 000 lux. Calculate the intensity on the screen at distances of:
(a) 2 m
(b) 3 m
(c) 4 m
I 1/I 2 = d^2 2/d^2 1
or something
I don't understand at all. I'm hoping you guys would be able to explain what I am meant to do here because the teacher fails at teaching.
Just give me the equation for (a) so that I have a better understanding of what the is going on which would hopefuly enable me to do (b) and (c).
Thank you.
I'm going to assume that the source is either a point source or a spherical, isotropic one.
The inverse square law applies for intensity, in that the intensity of the light at a point away from the source is inversely proportional to the square of the distance of that point from the source.
Mathematically,
[tex]I \varpropto \frac{1}{r^2}[/tex]​
Thus, problems can be solved using this proportionality:
[tex]I_{1} = \frac{k}{{r_{1}}^2}[/tex]
[tex]I_{2} = \frac{k}{{r_{2}}^2}[/tex]
[tex]\frac{I_{1}}{I{_2}} = \frac{{r_{2}}^{2}}{{r_{1}}^{2}}[/tex]
yes... i know the formula
i have it in my book
but i don't know HOW to use them
can you just show me where the numbers should go for (a) then I would probably understand
please
Using the final equation I posted, substitute the values:
[tex]I_{1} = 12 000, r_{1} = 1, r_{2} = 2[/tex]​
Then it follows that
[tex]I_{2} = I_{1}\,\frac{{r_1}^2}{{r_2}^2} = 12 000\,\frac{1^2}{2^2} = 3 000 \,lux[/tex]​
From this, the inverse square law becomes apparent: at double the distance, intensity decreases to a quarter, and so on.
ok thanks man
so if i were doing (b) would the answer be 1333.333 lux
Yes, but you need to round off appropriately.
14K
