| Thread Closed |
How the energy generated by nuclear fussion is extracted? |
Share Thread | Thread Tools |
| Feb10-10, 10:37 AM | #1 |
Anyone knows how? Thanks in advance
Correction to the question..Not extracted, but "capture" I can't think of any word to describe the process. Sorry for my poor English speaking skills |
| Feb10-10, 11:16 AM | #2 |
Diverting from the question...
Here's what i have found. The heat generated by the nuclear fusion is being transferred by a water-cooling loop to a heat exchanger to make steam. The steam then drives the Turbine to generate electricity. From what I understand, the heat is sort of use to heat water and produce steam. From there, the steam is used to drive a turbine to produce electricity. Correct me if I'm wrong. Adding on, as the heat is being transferred from the Tokamak, to the water, and the water turns to steam. From there steam is moved on to drive the turbine. In this process, the energy is being lost (due to heat loss to surrounding and etc.). The energy generated by the nuclear fusion will not be full utilize. Am I right to say that? |
| Feb10-10, 11:40 AM | #3 |
Are you talking about fusion, or fission? If this is fusion, then I think all of this is hypothetical. I don't think anybody has ever extracted useful energy from a nuclear fusion reactor.
But in any case, I don't think the aspects of the hypothetical design you're talking about really depend on whether it's fusion or fission. In both cases, a nuclear reaction generates heat, and that heat runs a heat engine. A steam turbine is one possible type of heat engine. |
| Feb16-10, 12:02 PM | #4 |
there are troubles to maintain a stable plasma environment with a desirable economic cost. It is more like you lose more energy in making fusion.
| Feb16-10, 05:29 PM | #5 |
There was an interesting article in Eric Drexler's blog:
Why fusion won’t provide power The bottom line is that using ITER like approaches to fusion don't lead to anything that is close to cost effective. Fission style power plants are an orders of magnitude cheaper than anything that can be produced by tokamak style power plants. There are also a number of interesting comments on this posting. They discuss other approaches to fusion that would be much cheaper if they work. |
| Mar28-10, 12:39 PM | #6 |
The power generation in an ITER type concept is to capture the high energy neutrons (14 MeV) evolved in the fusion process in a lithium breeding blanket. Being neutral the high energy neutrons can readily leave the confined plasma in which the fusion reaction takes place. Depositing 14 MeV neutrons in the lithium is going to mean it needs cooling and this is where the energy can be extracted - basically cooling (boiler?) tubes buried in the blanket pick up heat and convert water into steam and from there onwards it would be pretty much the same as most of the power plants in the world today. Of course bombarding any substance with such high energy neutrons is likely to cause serious issues and its notable that the design of suitable materials is to be carried out in parallel with the design and buildng of ITER. It's no secret that there are some incredibly difficult technical issues to overcome before fusion powered reactors can generate electricity on a commercial scale.
| Apr26-10, 08:00 AM | #7 |
The problem with indirect electrical power production schemes for fusion is, while more gross energy is produced than is consumed, the bands that we presently use are insufficent and the methods we use are inefficient. Heat engines work great when we don't have to put energy into containment as in fission and fossil production. When parasitic loads like containment are as high as they are, in fusion generation, you better be a lot more efficient at capturing energy in all bands than our paultry tech.
| Jul8-10, 04:40 PM | #8 |
I was just at a colloquium about ITER. The concept is just as statphys stated. The 'containment' vessel will be surrounded by a lithium breeding blanket where the 14MeV neutrons will deposit their energy. I cannot remember if the lithium itself acts as a coolant (or if water is fed through lines within the lithium blanket) which is then pumped through a heat exchanger/steam generator where the steam plant will be just like a conventional power/nuclear plant. The fusion reactor and associated primary coolant (Lithium) will be contained within the 'reactor containment' structure along with the steam generators. Yes, radiation (neutron/gamma) will deteriorate the structural integrity of the materials as statphys pointed out (called neutron 'embrittlement'), but this is accounted for by the materials chosen at the design stage which is dependent on the expected radiation flux through the material, and they replace these materials when necessary. This generates activated waste (yes, fusion power plants do create waste!), but this waste will decay in a few hundred years instead of 10,000.
| Jul15-10, 10:14 AM | #9 |
One of the most prevalent ideas being circulated is using a liquid salt to capture the energy of the neutron.
| Jul15-10, 02:21 PM | #10 |
Everyone is so skeptical of fusion...just because it doesn't work now doesn't mean it won't...we just have to find the right materials. Solar doesn't work on a commercial scale either but everyone loves that...pfff.
The best fusion tech is the SABR...using an unsustainable fusion source to get rid of transuranic waste...while still producing (net producing) power. Forget Yucca...SABRs and breeders for all. |
| Jul15-10, 03:23 PM | #11 |
I question whether SABR is really the fusion tech due to the use of a to tokamak; even the biggest supports say that the viability of the tokamak is +50 years.
As I see it, ICF is the best technology (at least as it stands now); it's only a year or two away... |
| Jul15-10, 03:53 PM | #12 |
SABR uses a tokamak, but those "viability" timelines are likely for a sustained fusion reaction in a tokamak...I would guess. The technology is already there for SABR.
ICF? A year or two away? Where? I don't know too much about ICF, my plasma prof (Stacey) pretty much shuns it and teaches tokamaks mostly. I doubt tokamak research would continue as such if ICF were so close...my guess is that it isn't that close. |
| Jul15-10, 05:39 PM | #13 |
Mentor
The reason I'm skeptical of fusion is how long it is taking. When the process of fission was discovered it took the rediculously short period of about 15 years for it to be implimented for power generation. We've known about fusion for more than half a century and have actively been pursuing harnessing it for many decades with seemingly little progress toward and no timeframe for success. |
| Jul15-10, 05:54 PM | #14 |
Mentor
https://lasers.llnl.gov/programs/ I've also never understood how you get net energy out of ICF -- does anybody know how the NIF plans to get energy out? |
| Jul15-10, 05:57 PM | #15 |
Mentor
| Jul16-10, 10:39 AM | #16 |
| Jul16-10, 10:42 AM | #17 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: How the energy generated by nuclear fussion is extracted?
| The energy of electrons extracted from a photocathode | General Physics | 0 | ||
| extracted energy of Uranium | Advanced Physics Homework | 2 | ||
| Nuclear Fission/Fussion | Forum Feedback & Announcements | 7 | ||
| fussion solutions,maybe | General Physics | 16 | ||
