| Thread Closed |
Mechanics question involving moments |
Share Thread | Thread Tools |
| Feb10-10, 02:57 PM | #1 |
A plank of wood is lifted off the ground so it has one side on the ground (A) and the rest of the wood at a slope at 15degrees to the horizontal. The length of the wood (AC) is 2.5m. A force is applied at C at 65degrees to the horizontal to the left keeping it in equilibrium. The mass of the wood is 90g and the centre of mass is at B (this was 1.875m from A when the wood was flat, so presuming that it is at the same point?). Show that the lifting force is 649N 2. Relevant equations Moment= Force x Perpendicular distance Total clockwise moments=total anticlockwise 3. The attempt at a solution Well i've tried taking moments about A so: Fsin65 x 2.5 = 90gsin15x1.875 But this doesnt give the right answer. Do I need to consider the reaction force at A? Or friction? Any help at all would be greatly appreciated. Many thanks. |
| Feb10-10, 06:52 PM | #2 |
We have two equilibrium conditions:
[tex]\sum_{i}\vec{F_{i}}=0[/tex] [tex]\sum_{i}\vec{\tau_{i}}=0[/tex] Forces on the body are actually not relevant, but it's good to consider them. Besides gravitational force [tex]\vec{F_{g}}[/tex] and force [tex]\vec{F}[/tex] acting at point C there is also a reaction force [tex]\vec{N}[/tex] on A and friction [tex]\vec{F_{fr}}[/tex] acting to the right. Vector sum of all these forces equals to zero. Another thing to consider is the net torque (which is also zero since body is not rotating). Since we don't know anything about reaction force and friction, we will calculate the torque relative to point A in order to eliminate them. (Distances of those forces from point A are zero, so the torques are also zero). Torque is defined as [tex]\vec{\tau}=\vec{r}\times\vec{F}[/tex] [tex]\tau=rF\sin{\varphi}[/tex] So we have [tex]\vec{\tau_{B}}+\vec{\tau_{C}}=0[/tex] Algebraically [tex]\tau_{B}=\tau_{C}[/tex] [tex]mgl\cos{\alpha}=FL\sin{(\alpha+\beta)}[/tex] Where [itex]m=90[/itex] kg, [itex]L=2.5[/itex] m, [itex]l=1.875[/itex] m, [itex]\alpha=15^{\circ}[/itex], [itex]\beta=65^{\circ}[/itex]. Angles are easily understood by looking at the geometry of the problem. Finally, lifting force is [tex]F=\frac{mgl\cos{\alpha}}{L\sin{(\alpha+\beta)}}[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mechanics question involving moments
| Statics Question involving forces and moments | Engineering, Comp Sci, & Technology Homework | 2 | ||
| Problems in Statics Involving Moments related to rigid bodies | Engineering, Comp Sci, & Technology Homework | 9 | ||
| As level mechanics unit 1 question on moments. | Introductory Physics Homework | 4 | ||
| Mechanics Question, Moments | Precalculus Mathematics Homework | 11 | ||
| Mechanics question involving pulleys: where is the problem? | Advanced Physics Homework | 2 | ||
