| Thread Closed |
Finding indexes. |
Share Thread | Thread Tools |
| Feb12-10, 04:07 PM | #1 |
Finding indexes.
I for the most part have this completed but I have a small question and thus checking if I did this correctly.
1. The problem statement, all variables and given/known data Given the Sequence = [tex]\frac{n}{n+2}[/tex] [tex]\approx_{\epsilon}[/tex] 1 , for n >> 1 Show what index if [tex]\epsilon[/tex] = .001 " " if [tex]\epsilon[/tex] = .000002 " " for any [tex]\epsilon[/tex] > 0 2. Relevant equations N/A 3. The attempt at a solution for [tex]\epsilon[/tex] = .001 I did: [tex]\left|\frac{n}{n+2}-1\right|< .001[/tex] [tex]\left|\frac{-2}{n+2}\right| < .001[/tex] [tex]\frac{2}{n+2} < .001[/tex] [tex]\frac{2}{n+2} < \frac{1}{1000}[/tex] [tex]\frac{n+2}{2} > 1000[/tex] [tex]n+2 > 2000[/tex] [tex]n > 1998[/tex] The only issue I have with this one and the next one is that they aren't decreasing and I'm not sure if it needs to be or not: [tex]\frac{1999}{1999+2} = .9990004998[/tex] [tex]\frac{2000}{2000+2} = .9990009990[/tex] for [tex]\epsilon[/tex] = .000002 I did: [tex]\left|\frac{n}{n+2}-1\right|< .000002[/tex] [tex]\left|\frac{-2}{n+2}\right| < .000002[/tex] [tex]\frac{2}{n+2} < .000002[/tex] [tex]\frac{2}{n+2} < \frac{2}{1000000}[/tex] [tex]\frac{n+2}{2} > \frac{1000000}{2}[/tex] [tex]n+2 > 1000000[/tex] [tex]n > 999998[tex] for any [tex]\epsilon[/tex] > 0 [tex]\left|\frac{n}{n+2}-1\right|< \epsilon[/tex] [tex]\left|\frac{-2}{n+2}\right| < \epsilon[/tex] [tex]\frac{2}{n+2} < \epsilon[/tex] [tex]\frac{n+2}{2} > \frac{1}{\epsilon}[/tex] [tex]n+2 > \frac{2}{\epsilon}[/tex] [tex]n > \frac{2}{\epsilon}-2[/tex] |
| Feb12-10, 04:31 PM | #2 |
Mentor
| Feb12-10, 04:42 PM | #3 |
I got n > 1998 as the index so, [tex]\frac{1999}{1999+2} = .9990004998[/tex] [tex]\frac{2000}{2000+2} = .9990009990[/tex] |
| Feb12-10, 07:52 PM | #4 |
Mentor
Finding indexes.
This is to be expected in a sequence that is increasing, as {n/(n + 2)} is. A larger index gives you a larger value.
| Feb13-10, 06:09 AM | #5 |
As Mark44 said, that is to be expected. [itex]\epsilon[/itex] being smaller means you must get closer to the limit value which, in turn, means you must go further out in the sequence. As [itex]\epsilon[/itex] gets smaller, you should expect the index, N, to get larger, not smaller.
You may be thinking of function limits, [itex]\lim_{x\to a}f(x)[/itex] where to get closer to the limit, you must get closer to a: smaller [itex]\epsilon[/itex] means smaller [itex]\delta[/itex]. But with [itex]\lim_{n\to \infty} a_n[/itex] or even [itex]\lim_{x\to\infty} f(x)[/itex], your "a" is [itex]\infty[/itex] so you must get "closer to infinity" which means larger. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Finding indexes.
| Anyone know of experiments to calculate the refractive indexes of liquids? | Introductory Physics Homework | 4 | ||
| grammar (ref index/indexes/indices) and appendix quesrtion | Academic Guidance | 4 | ||
| Citation indexes for mathematical physics | Math & Science Software | 2 | ||
| Changing the summation indexes in double sums. | Calculus & Beyond Homework | 1 | ||
