Question regarding D'Alembert solution for one dimension wave equation
The discussion revolves around the D'Alembert solution for the one-dimensional wave equation, focusing on specific steps and interpretations of the solution as presented in a reference from Wolfram. Participants explore the mathematical derivation, clarify notation, and question the integration steps involved in the solution process.
  • One participant seeks verification of the differentiation step in the D'Alembert solution, questioning the correctness of the transition from the wave function at t=0 to the expression involving derivatives of f and g.
  • Another participant confirms the correctness of the differentiation step but suggests that the notation could be clearer.
  • There is a discussion about the dummy variable 's' used in integration and the meaning of the constant 'α', with some participants agreeing that 'α' is not critical to the final formula.
  • One participant expresses confusion about how the integration leads to the final form of the wave equation and seeks reassurance regarding their understanding of the calculus involved.
  • Clarifications are provided regarding the substitutions made in the expressions for y(x,t) and the interpretation of y_0(x) in relation to the wave function at t=0.
  • Concerns are raised about the educational context, with one participant sharing their experience of studying independently and feeling uncertain about their mathematical skills.
Participants generally agree on the correctness of certain steps in the derivation, but there remains some uncertainty regarding the integration process and the implications of the constants involved. The discussion does not reach a consensus on all points, particularly regarding the clarity of notation and the completeness of the integration steps.
Some participants note that the integration steps may not be entirely correct, suggesting that additional terms could be present but ultimately do not affect the final formula. There is also mention of the educational background of participants, which may influence their confidence in the mathematical reasoning presented.
This discussion may be useful for students and practitioners studying partial differential equations, particularly those interested in wave equations and the D'Alembert solution, as well as individuals seeking clarification on mathematical derivations in this context.
yungman
In am studying PDE and I have question about D'Alembert solution for one dimension wave equation.
I am going to reference Wolfram:
http://mathworld.wolfram.com/dAlembertsSolution.html
1) I want to verify the step of [tex]\frac{\partial y_0}{\partial t}[/tex] of step (14) of the page.
[tex]\Rightarrow\; \frac{\partial y_0}{\partial t}=v_0\; =\; \frac{ \partial f(x-ct)}{\partial (x-ct) } \frac{ \partial (x-ct)}{\partial t }\; + \;\frac{ \partial g(x+ct)}{\partial (x+ct) } \frac{ \partial (x+ct)}{\partial t }[/tex]
[tex]=\; c[\frac{ \partial f(x-ct)}{\partial (x-ct) }\;- \; \frac{ \partial g(x+ct)}{\partial (x+ct) }]|_{t=0} \;= \; -c\frac{ \partial f(x)}{\partial (x) }\;+ \; c\frac{ \partial g(x)}{\partial (x) } \;=\; -cf'(x)+cg'(x)\;\;\; (14)[/tex]
Am I correct on the steps?
2) I don't follow step (16)
[tex]\int_{\alpha} ^x \; v_0(s)\; ds = -cf(x) +cg(x) \;\;\; (16)[/tex]
a) Where is [tex]s[/tex] come from? Is it just a dummy variable for substitude for x and [tex]\alpha[/tex] later?
Where is [tex]\alpha[/tex] come from?? Is it supposed to be 0 instead?
b) [tex]\int_{\alpha} ^x \; v_0(s)\; ds = \int_{\alpha} ^x -cf'(x) +cg'(x) \; = [-cf(x)+cg(x)]_{\alpha}^x[/tex]
This don't agree with [tex]\int_{\alpha} ^x \; v_0(s)\; ds = -cf(x) +cg(x) \;\;\; (16)[/tex]
Please refer to (14) and (16) in Wolfram page.
1) It is correct. I am guessing [tex]y_{0}[/tex] is the wave function at t=0? (you'll have to be more accurate with notations)
2)Yes, s is just a dummy variable. [tex]\alpha[/tex] is actually a meaningless constant (could be zero as well). I agree with you that technically the integration is not correct (there should be another term with s=[tex]\alpha[/tex]), but if you look forward into the formula derivation you'll see that this extra term cancells out and has no part in the final formula, so it's not very critical.
thanks for the response
I was referring to the page in Wolfram provided, that's the reason I did not explain what is y0.
Is D'Alembert only for one dimension only?
New question on D'Alembert solution.
Please refer to this:
[tex](17)\;\Rightarrow \; f(x)=\frac{1}{2}y_0\; -\; \frac{1}{2c} \int_{\alpha}^x \; v_0(s) ds[/tex]
[tex](18)\;\Rightarrow \; g(x)=\frac{1}{2}y_0\; +\; \frac{1}{2c} \int_{\alpha}^x \; v_0(s) ds[/tex]
[tex]Plug\;(17)\;&\;(18)\; into \; (13)\; \Rightarrow\; y_0(x) \;=\; f(x)\;+\; g(x)\; = \; y_0\;![/tex]
How does it become [tex]y(x,t) \; = \;\frac{1}{2} y_0(x\;-\;ct)\; +\; \frac{1}{2} y_0(x\;+\;ct)\; +\; \frac{1}{2c} \int_{x-ct}^{x+ct} \; v_0(s) ds \;\; ??[/tex]
My eqestion is:
1) If I pluging (17) and (18) into (13), I only get Y0(x) that cannot turn into (19) by putting t back in.
The way I explain to myself, please tell me I am correct. Also I still have one more question below. Yes, I have no confidence on my calculus, I need some reassurance. I also added f(a) and g(a) terms from integration, please look and tell me if I am correct.
[tex]y_0(x) \;= f(x) + g(x)\;,\; putting \;t \;back\; \Rightarrow\; y(x,t)\;= \;f(x-ct)\; +\; g(x+ct)[/tex]
[tex](16)\Rightarrow\; \int_a^x \; v_0(s)\; ds \;=\; c[-f(s)\; +\;g(s)]_a^x \;=\; c[-f(x) \;+\; f(a) \;+\; g(x) \;-\;g(a)] \;\;where\; a\; is\; a\; dummy\; constant[/tex]
[tex](17)\; \Rightarrow \; f(x-ct) \; =\;\frac{1}{2} y_0(x-ct)\; - \frac{1}{2c}\int_{\alpha}^{x-ct} \;v_0(s)\; ds \;-\frac{f(a)}{2c}\;+ \;\frac{g(a)}{2c}\;[/tex]
[tex]=\; \frac{1}{2} y_0(x-ct)\; + \frac{1}{2c}\int _{x-ct}^{a} \;v_0(s)\; ds \;-\frac{f(a)}{2c}\;+ \;\frac{g(a)}{2c}\;[/tex]
[tex](18)\; \Rightarrow \; g(x+ct) \; =\;\frac{1}{2} y_0(x+ct)\; - \frac{1}{2c}\int_{\alpha}^{x+ct} \;v_0(s)\; ds \;+\; \frac{f(a)}{2c}\;- \;\frac{g(a)}{2c}[/tex]
[tex]Therefore\;\; y(x,t)\;= \;f(x-ct)\; +\; g(x+ct)\; = \;\frac{1}{2} y_0(x\;-\;ct)\; +\; \frac{1}{2} y_0(x\;+\;ct)\; +\; \frac{1}{2c} \int_{x-ct}^{x+ct} \; v_0(s) ds \;\;[/tex]
[tex]What \;is \; y_0(x+ct) \; and \; y_0(x-ct)\; ?[/tex]
Is it just take [tex]y_0(x)[/tex] and substitude every x with x+ct or x-ct?
You explained it very well.
And yes, y(x+ct) is making the change x->x+ct in y(x)
I want to confilm that you mean [tex]y_0(x)[/tex] which is y(x) with t=0. When equating x=x+ct or x=x-ct on all the x in [tex]y_0(x)[/tex] will not equal back to the original y(x,t). Also [tex]y_0(x-ct)\; and\; y_0(x-ct)[/tex] are not equal.
Thanks very much of your time. I don't go to school and just studying at home. I don't quite trust myself. I find going to school is very high pressure and I was very disappointed after looking at what the class cover. The class skip over the Laplace and Poisson equation. Only cover lightly on Bessel and Legendre differential equations. I am studying electromagnetics and antenna, not really studying math. Somehow both the ODE and PDE class spent a lot more time in heat equation than wave equation and Poisson.
Anyway I don't want to bore you with all this. Thanks.
Alan
I meant a general function y(x), not necessarily related to the problem.
Of course d'Alambert's formula does this with y0 and twice (once with x+ct and the other time with x-ct)
Thanks.
  • · Replies 19 ·
