What is the minimum frequency of light needed to eject electrons from a metal?
  • Thread starter Thread starter supermenscher
    Photon Theory
The discussion revolves around determining the minimum frequency of light required to eject electrons from a metal, specifically focusing on the relationship between work function and frequency. The problem is situated within the context of photoelectric effect principles.
  • Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the equation relating frequency, work function, and kinetic energy, with some questioning the correctness of their calculations. There is also a secondary problem introduced regarding Compton scattering, prompting inquiries about which wavelength to solve for.
Some participants have provided guidance on the approach to the photoelectric effect problem, suggesting that the minimum frequency corresponds to zero kinetic energy. Others are attempting to clarify their calculations and seek further assistance on the Compton scattering problem, indicating an ongoing exploration of the topics.
There is mention of potential confusion regarding unit conversions, specifically between joules and electron volts, as well as the need to clarify which wavelength to consider in the Compton scattering problem.
supermenscher
What minimum frequency of light is needed to eject electrons from a metal whose work function is 4.1*10^-19J.
I converted the work function to electron volts and I know that hf = KE+W
and f=KE+W/h but where to I go from there?
Good start. The minimum frequency corresponds to KE=0. That is, the photon is just energetic enough to get the electron out of the metal, but not to give it any KE.
So is it just f=W/h I did that and got the wrong answer...and can you help me with another problem.
X-rays of wavelength 0.120nm are scattered from a carbon block. What is the compton wavelength shift for photons detected at the 45 and 180 degrees relative to the incident bean. I did wavelength` = wavelength +h/mc (1-cos theta) I did the problem both ways, solving for wavelength` and wavelength and got the answer wrong both times...any help?
If you got the wrong answer, then you must have done something wrong. Show your work and let's find out.
Again, your methods seem OK to me. Show us the details of what you did.
For the first one I did f=W/h = 4.1*10^-19J (1/1.6*10^-19J)=2.565ev
f=2.565ev/6.626*10^-34=3.86710^33
For the second one, which wavelength do i solve for, wavelength` or wavelength because it says with respect to the incident beam
For some reason, you converted the work function from J to ev. Don't. The value of h that you used has units of Joule-sec.
I will rewrite the Compton formula like this:
[tex]\lambda_f = \lambda_i + \frac{h}{m_e c} (1-cos\theta)[/tex]
You are given the initial wavelength of the incident beam [itex]\lambda_i[/itex]; solve for the final wavelength [itex]\lambda_f[/itex].
  • · Replies 35 ·
  • · Replies 25 ·
