Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Mathematics > Calculus & Analysis
Reply
image hints only please: compact iff bicompact Share It Thread Tools Search this Thread image
Old Aug2-04, 07:47 PM                  #1
phoenixthoth
phoenixthoth's Avatar
phoenixthoth is Offline:
I'd like hints only please. I have an analysis book and I could look up the proof myself but I'm trying to prove it myself as an exercise; so giving the full proof would be redundant as well as counterproductive to my own learning.
X is a metric space.
In this other book, K is compact iff every sequence in K has a convergent subsequence. I know that topologically, this is not the standard definiton of compact; some authors would call this sequentially compact.
K is bicompact if every open cover of K admits a finite refinement that also covers K. This is how compactness is usually defined as far as I knew.
Hints on how compact implies bicompact and bicompact implies compact would be very much appreciated.
Right now, I'm working on compact implies bicompact so that is the current priority. I don't need hints on the other direction at this time since I haven't tried it.
A general hint like "prove the contrapositive" or "use contradiction" might be helpful though I've tried the first of the two already. I suppose as I await a reply, I'll try contradiction...
Thanks!
Old Aug2-04, 07:59 PM                  #2
plover
plover is Offline:
Recognitions:
Homework Helper Homework Helper
Did you mean "K is a metric space"?
Old Aug2-04, 08:31 PM                  #3
phoenixthoth
Sorry for the oversight. I meant that X is a metric space and that K is a subset of X.
Old Aug3-04, 01:54 PM       Last edited by arildno; Aug3-04 at 02:14 PM..            #4
arildno
arildno is Offline:
Recognitions:
PF Contributor PF Contributor
Thanks!
I'll give you 2 lemmas to prove first:
1. If K is (sequentially) compact, then K is totally bounded.
(A set is called totally bounded, if for any e>0, there exist a finite set LaTeX Code: \\{x_{k}\\}\\in{K} such that K is covered by the union of disks LaTeX Code: D(x_{k},e) )
2.Let LaTeX Code: \\{U_{i}\\} be an open cover of K.
Then there exist r>0, such that for any LaTeX Code: y\\in{K} , the open disk
D(y,r) is contained in some LaTeX Code: U_{i}
(I thought 2. was shockingly strong the first time I saw it..)
Proof by contradiction..
Old Aug3-04, 09:40 PM                  #5
phoenixthoth
Thank you so much. I went ahead and proved that compact --> bicompact using the two lemmas; now I'm working on proving the first lemma. I'm sort of stuck on it though I haven't tried everything yet. In the next day or two, I may ask for a hint on how to prove lemma 1. I'm now resorting to proving it with contradiction. I want to exhibit a sequence with no convergent subsequence... Still working on it. Thanks again.
Old Aug4-04, 03:51 AM                  #6
arildno
arildno is Offline:
Recognitions:
Good luck!
I guess you've already figured out how the two lemmas together will prove your main objective..
Old Aug4-04, 04:57 PM                  #7
phoenixthoth
How does this look for a proof of the first lemma?
We will show that if LaTeX Code: K is not totally bounded then LaTeX Code: K is not compact by constructing a sequence in LaTeX Code: K that has no convergent subsequence. Let LaTeX Code: x_{1} be any element of LaTeX Code: K . Note that since LaTeX Code: K is not totally bounded, LaTeX Code: K is not covered by LaTeX Code: B_{1}\\left( x_{1}\\right)  . So let LaTeX Code: x_{2}\\in K\\backslash B_{1}\\left( x_{1}\\right)  . Likewise, LaTeX Code: K is not covered by LaTeX Code: B_{1}\\left( x_{1}\\right) \\cup B_{2}\\left( x_{2}\\right)  . For LaTeX Code: n>2 let LaTeX Code: x_{n}\\in K\\backslash \\bigcup_{i=1}^{n-1}B_{1}\\left( x_{i}\\right)  . LaTeX Code: x_{n} exists because if LaTeX Code: K is covered by LaTeX Code: \\bigcup_{i=1}^{n-1}B_{1}\\left( x_{i}\\right)  , it would be totally bounded. The sequence LaTeX Code: \\left\\{ x_{i}\\right\\}  has no convergent subsequence because for all (unequal) LaTeX Code: i,j , LaTeX Code: d\\left( x_{i},x_{j}\\right) >1 and if there were an increasing function LaTeX Code: \\tau :Z^{+}\\rightarrow Z^{+} such that there is an LaTeX Code: I\\in Z^{+} such that if LaTeX Code: i\\geq I , then LaTeX Code: d\\left( x_{\\tau \\left( i\\right) },x\\right) <1/2 for some LaTeX Code: x\\in X . That would imply that LaTeX Code: d\\left( x_{\\tau \\left( I\\right) },x_{\\tau \\left( I+1\\right) }\\right) \\leq d\\left( x_{\\tau \\left( I\\right) },x\\right) +d\\left( x,x_{\\tau \\left( I+1\\right) }\\right) <1 when we know that LaTeX Code: d\\left( x_{\\tau \\left( I\\right) },x_{\\tau \\left( I+1\\right) }\\right) >1 . Therefore LaTeX Code: K is not compact as we have exhibited a sequence with no convergent subsequence.
Old Aug4-04, 05:14 PM                  #8
arildno
arildno is Offline:
Recognitions:
Is LaTeX Code: B_{1} a ball with radius 1?
If so, your argument is (slightly) flawed:
The negation is:
There exist some e>0 such that K cannot be covered by finitely many balls of radius e.
(As far as I can see, you can merely substitute e for 1 in your argument to get the proof)
Old Aug4-04, 07:36 PM                  #9
phoenixthoth
Cool deal. Now I'm working on the second lemma...
Old Aug4-04, 11:14 PM                  #10
phoenixthoth
Could I have a hint for the second lemma? Thanks in advance.
Old Aug5-04, 06:37 AM                  #11
arildno
arildno is Offline:
Recognitions:
The negation is:
For every r>0, there exist some y in K, such that the disk D(y,r) is not (fully) contained in any Ui
image image
Reply
Thread Tools
Similar Threads for: hints only please: compact iff bicompact
Thread Thread Starter Forum Replies Last Post
compact-valued range doesnot imply compact graph CHatUPenn Calculus & Analysis 3 Mar22-08 05:31 AM
compact subset of a locally compact space ehrenfest Calculus & Beyond 5 Nov7-07 01:34 AM
need some hints neik Precalculus Mathematics 3 Feb14-07 11:47 PM
A function on a compact set is compact eddo Calculus & Analysis 8 Mar30-05 02:16 PM
Any Hints!?!? Fused Introductory Physics 4 Sep30-04 05:31 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
