How is the magnetic field of a bar magnet measured and utilized?
The discussion centers on the measurement and utilization of the magnetic field generated by a bar magnet. It establishes that the classical model, which describes magnetic moments at the atomic level, is not the source of ferromagnetism. Instead, ferromagnetism arises from the magnetic moments of electrons in iron's outer shell, as described by the Dirac equation. The bound surface current at the magnet's surface can be measured through the turning moment caused by an external magnetic field, similar to how currents are measured in galvanometers.
  • Understanding of classical electromagnetism
  • Familiarity with the Dirac equation and quantum mechanics
  • Knowledge of magnetic fields and their measurement techniques
  • Basic principles of ferromagnetism
  • Research the Dirac equation and its implications for electron behavior
  • Study the principles of ferromagnetism in materials like iron
  • Learn about the Biot-Savart law and its applications in electromagnetism
  • Explore methods for measuring magnetic fields using galvanometers
Physicists, electrical engineers, and students studying electromagnetism and materials science will benefit from this discussion, particularly those interested in the principles of magnetism and its practical applications.
Wannabeagenius
Hi All,
The classical theory of a bar magnet as I understand it is that there are many current loops at the atomic scale which have magnetic moments all pointing in the same direction. At the interior of the magnet, with one loop next to the other, currents go in opposite directions and their effects are canceled. However, at the surface of the magnet, small current loops are not canceled by adjacent loops which results in a current circulating around the outside of the magnet which causes the resulting magnetic field according to the Biot-Savart law.
If this description is true, which I think it is, how is this current measured? Also, is it possible to use this current and if so, what would the effect be? It seems that the bar magnet would gradually lose its magnetism.
Thank you,
Bob
That is the standard classical model, but it is not in fact the source of ferromagnetism.
Ferromagnetism arises from the magnetic moments of two electrons in the outer shell of iron. But these magnetic moments come from the spin of th electron, treated quantum mechanically by the Dirac equation. In this theory, the point electron has a magnetic moment, but there is no current loop. There still is a bound surface current at the surface of the magnet. It is a real current in the sense that it produces the strong solenoidal B field, but it cannot utilized in any other way because it is bound in the material. The bound current can be measured in the same way as most currents are measured, which is by the turning moment caused by the action of an external B field on it. For a compass, the turning moment is on the compass needle. For an ordinary current, the turning moment is caused by a B field in a galvanometer acting on a wire loop carrying the current.
Thanks Clem.
Nice explanation.
  • · Replies 16 ·
