Electromagnetic Waves: How & Why They Store Info
The discussion centers on how electromagnetic (EM) waves can store information, exploring the mechanisms and principles behind this process. It includes theoretical aspects and practical applications related to information encoding in EM waves.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant questions the fundamental mechanism by which electromagnetic waves store information.
  • Another participant suggests that information can be stored by turning EM waves on and off, likening it to Morse code, and notes that higher frequency waves can store more information due to their ability to be modulated at higher rates.
  • A third participant provides links to amplitude modulation and frequency modulation as schemes used for carrying information on radio waves.
  • Further, a participant explains that information can be encoded by modulating various properties of the light field, such as polarization, frequency, and pulse duration, and emphasizes that any physical property of an EM field can potentially be used for information encoding.
  • One participant expresses gratitude for the contributions, indicating their usefulness for personal research.
Participants present various methods and ideas regarding information storage in EM waves, but there is no consensus on a singular mechanism or approach, indicating multiple competing views remain.
The discussion does not resolve the complexities of how different modulation techniques compare or the specific limitations of each method mentioned.
physixlover
How does the electromagnetic waves store information, what makes these waves to store. (this may be a stupid question but i need to know how)
Thanks.
Information (the kind that we humans use) can be stored in turning the EM wave on and off (kinda like Morse code, but a lot more complicated). This turning on and off mechanism is why higher frequency EM waves can "store" more information, since they can be turned on and off at higher frequencies without destroying the wave.
This method is used for Fiber Optics I believe (I'm not 100% since I haven't really studied this).
It's up to you to modulate the properties of a light field in some way so as to allow someone later to measure these modulations and extract data from them. A simple way might be to send a train of pulses whose polarizations are set to be either vertical or horizontal (as defined by me). I can associate bit values with these two physical states and transmit a bit stream to a person who knows to measure polarizations with a beam splitter (oriented in the correct direction) and a couple of photodetectors.
In principle you could use just about any physical property of an E/M field to encode information (frequency, spatial mode, pulse duration, pulse energy, polarization, etc.).
More generally, you can store information in any physical system whose properties you can arrange in specific ways.
thanks guys,good posts ,your posts will be very helpful for my research
  • · Replies 21 ·
  • · Replies 28 ·
  • · Replies 65 ·
