The fan mode of an Air Conditioner?
The discussion revolves around the functionality of the fan mode in split air conditioning units. Participants explore whether this mode simply circulates indoor air or facilitates air exchange with the outdoors. The conversation includes various perspectives on air conditioning modes and their operations.
  • Some participants suggest that in fan mode, the air conditioner primarily circulates indoor air, similar to a regular fan.
  • Others question whether the fan mode allows for air exchange with the outdoor environment, indicating uncertainty about the role of the connecting pipe between indoor and outdoor units.
  • One participant mentions that their thermostats include modes such as COOL, FAN, HEAT, and AUTO, asserting that the fan mode is intended for air circulation and filter operation.
  • A participant with a window unit describes their modes and suggests that some window units may have a vent mode for outdoor air exchange.
  • Another participant expresses confusion about the modes displayed on their remote control, which are represented by symbols rather than text.
  • A later reply clarifies that the original poster's unit is a split system, not a central unit, which adds to the discussion about the functionality of different air conditioning systems.
Participants do not reach a consensus on the exact functionality of the fan mode, with multiple competing views remaining about whether it solely circulates air or also facilitates outdoor air exchange.
Some participants express uncertainty regarding the specific modes and their functions, and there are references to different types of air conditioning systems, which may affect the discussion.
Riscilla
Hi friends,
My air conditioner is a split one (it has 2 parts: one inside the house and the other outside). It has 4 modes of operation: cool, fan, and 2 other modes.
My question is that what does the machine really do in the fan mode? I wonder whether it just serves as a normal fan (which means it just circulates the air inside the room), or it can help exchange the air inside the room with the outdoor air?
Thanks for reading my question.
Riscilla.
Riscilla said:
Hi friends,
Riscilla.
ans. In fan mode the cylindrical roller at the bottom of AC spins which regulates the indoor air
What are the other two modes?
On all of my thermostats they were COOL, FAN, HEAT and AUTO. The fan does exactly what you think, it is intended to simply circulate the air and run it through your furnace filter. A lot of people advocate doing this.
Thank you for your answers. So the pipe connecting the indoor and outdoor units is of no use in this mode? I guess that this pipe is only used to transfer the coolant gas, and hence is only used in the cool mode, am I correct?
I don't know, because in the remote control, the modes are displayed as symbols, not text. Indeed I have never tried those modes before.
sounds like you have a window unit. Thats what I cool with, too (I believe they end up being more efficient than central systems) It seems as though the fan only recirculates the air in the room. Some window units also have a vent mode, where you can open an internal door between both sides. On mine the modes are: low cool, high cool, economy mode, and fan
dr
Oh. I made the assumption (bad I know) that it was a central unit. Whoops.
No the OP said it was a split system: a central air handler with remote condenser.
Something like the Mitsubishi's that I help install. Very efficient and stylish units I might add.
I have an air conditioner unit. It sits on the windowsill of my apartment. The maker appears to be a registered trademark named Simplicity. The unit has the two modes, air conditioner mode and fan mode. It seems to have a control for three speeds, high, medium and low. Then there is a control to make two blades glide back and forth. I should think those are to circulate the air inside the apartment here? These blades have a switch for close and open. The unit has what looks like a timer control, it is a button with a clock symbol. I guess that is so the air conditioner goes on and off at a specified hour. There are the important temperature controls. One control that has got me a little confused is a button with a picture of a pointing finger. Pressing that seems to turn off the fan or air conditioner. Is that for turning off those functions while keeping the unit active? The power on/off switch I understand. Any information is welcome to illuminate my understanding.
  • · Replies 16 ·
10K
  • · Replies 19 ·
